RS3000 TVIP system w/complete wiring harness
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by jonesbt, Jan 25, 2020.
  1. Jan 25, 2020 at 9:08 PM
    jonesbt
    jonesbt [OP] Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    Just pulled an RS3000 system out of a 1999 tacoma. I do not have a fob for this system, but I have the complete wiring harness, piezo buzzer, glass break sensor, microphone, indicator light, original wire splice clamps, and all of that jazz.
    $110 Shipped OBO
  2. Jan 31, 2020 at 9:56 AM
    jonesbt
    Brett
    Monroe, La
  3. Jan 31, 2020 at 9:53 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    @Empty_Lord Might've just found what I need for the flatbed...
  4. Jan 31, 2020 at 10:00 PM
    jonesbt
    Brett
    Monroe, La
    You sure did! Lets make it happen.
  5. Jan 31, 2020 at 10:10 PM
    04Pre_Runner
    Andrew
    If I can verify that it just plugs up to my 99 we have a deal. I need to go out and take the kick panel off to look at electrical harnesses.
  6. Jan 31, 2020 at 10:12 PM
    jonesbt
    Brett
    Monroe, La
    I pulled this off of a 99. I think it should be a perfect match. Theres an instruction sheet for installing these kits floating somewhere around the internet. I'll take a look for it while you look at your plugs. I have a few pictures of where some of the plugs/wires go, but I didn't take many.
    04Pre_Runner likes this.
  7. Jan 31, 2020 at 10:15 PM
    jonesbt
    Brett
    Monroe, La
    https://www.parksoffroad.com/tacomamods/miscinfo/vip3000alarminstallation.pdf
    These are instructions for an 01. The plugs and associated wiring between the two trucks are the same though... at least they were between the 99 I pulled this from and my 2001.
    I bought the 99 as a 4wd parts truck and saw that security system hiding in there. I knew a TW member would need it more than whatever Arkansas Random Joe ends up buying this 99 truck from me in a few weeks with their tax return money lol
  8. Jan 31, 2020 at 10:28 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Say who now?
  9. Jan 31, 2020 at 10:28 PM
    Empty_Lord
    Dan
  10. Feb 2, 2020 at 5:50 PM
    04Pre_Runner
    Andrew
    Not seeing every connection the instructions mention but the instructions look poorly drawn in some areas. Instructions mentioned the beeper in the engine bay plugs into an electrical connection that's plugged. Well I have a couple free plugs on this truck but not sure if those two are it. As you can see this truck has been entirely submerged up to the steering wheel on the driver side.
    5F1CC5AB-B07D-43D4-966D-761996C378D0.jpg BA5E367C-25D9-46DC-ADE0-58E0B5AAF8CF.jpg 9EF31D11-4E7D-444A-8980-58BF9A75FABE.jpg
  11. Feb 2, 2020 at 9:05 PM
    jonesbt
    Brett
    Monroe, La
    @04Pre_Runner
    Here are a few pictures from when I was pulling the system that may help you out. I can't image that the wiring harness is any different. A lot of the plugs were behind the fuse box like up high. The harness is designed so that some plugs in your truck will be unplugged and plugged into this harness.... this harness will then be plugged into the location of that connector that you just removed. It basically makes a loop through the TVIP harness and back into the truck wiring. Most of the wiring you should be looking for likely already has stuff plugged into it.
  12. Feb 2, 2020 at 9:52 PM
    04Pre_Runner
    Andrew
    Yeah I'll have to look around a bit harder. This truck has been in two front end collisions so some of the engine bay harnesses just aren't in their normal spots anymore.
  13. Feb 2, 2020 at 9:57 PM
    jonesbt
    Brett
    Monroe, La
    Perseverance. I like it. Keep that thing on the road.
    I would like to pretend that wiring comes naturally to me. I honestly wouldn't know how to wire up one of these systems without physically holding the plugs in my hand and digging through my truck looking for the matching plugs, haha. Now that I've taken a couple of the out of various Tacomas its gotten easier.
  14. Feb 2, 2020 at 10:13 PM
    jonesbt
    Brett
    Monroe, La
  15. Feb 6, 2020 at 4:25 PM
    04Pre_Runner
    Andrew
    Got after things today and determined that all I'm missing is the piezo buzzer harness in the engine bay. Or the 01 (the manual I'm following) had a separate harness in the engine bay and in 99 it's parts of the RS3000 harness.
    Your pictures makes it look like the buzzer is attached and can't disconnect so I'm hoping that's the case. I also found a slight difference in one harness under the steering wheel. My connector is blue with less wires than the picture you posted. But mine still has the red and green wire that needs to be spliced into.
  16. Feb 6, 2020 at 4:52 PM
    Empty_Lord
    Dan
    :redxfall::redxfall:
    04Pre_Runner[QUOTED] likes this.
  17. Feb 6, 2020 at 10:26 PM
    jonesbt
    Brett
    Monroe, La
    Do you have cruise control? That could explain the differences in wire count between my pictures and yours under the steering column.
  18. Feb 6, 2020 at 10:31 PM
    04Pre_Runner
    Andrew
    Yeah it has cruise. But also 3 pedals.
  19. Aug 1, 2020 at 11:29 PM
    NikkoCharger
    NikkoCharger Active Member
    Dontae
    rusty '01 Double Cab
    I pm'd you!
