Rsca light/system malfunction?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by plutodc, Jun 3, 2012.
  1. Jun 3, 2012 at 6:51 PM
    plutodc
    plutodc [OP] New Member
    I am new here and thanks in advance for the question i am about to ask. Me and my wife just got a new 2012 Tacoma. It only has 4k miles on it the rsca indicator light on the dash has been coming on and off at will i thought nothing of it. But today the light has stayed on constantly dimley lit and when i actually hold the button down it brightens up and the low tire pressure light comes on at the same time weird? From everything i have been reading the light should only come on for a few seconds when the truck is started and should not ever been on until the button is held down to turn the air bags off if i am correct. I am thinking there might be a bad sensor in the truck? I am not too sure but i wanted to get some advice on what might be wrong i am going to drop the truck off at the local dealer in the AM.
    Thanks again!
  2. Jun 4, 2012 at 4:37 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Have you or anyone else done any work inside the dash? Remote starter, radio, etc?
  3. Jun 4, 2012 at 6:26 AM
    plutodc
    Nope my wife just came back home from work and she said the light went off again... I am going to take it in i guess when we go get an oil change and just have them look it over!
  4. Sep 3, 2017 at 8:55 PM
    JediYoda
    JediYoda Awesome Member
    Nick
    Alaska / Arizona / Hawaii
    2010 TRD off-road AC MGM
    I encountered this same problem today on my way to work. I thought the button RSCA was accidently pressed, but I found when I pressed the RSCA button the tire pressure light and the 'RSCA off' light illuminated brightly. Then when I hold the RSCA button again, the 'RSCA off' light goes back to dim. I drive a 2010 TRD off-road, access cab, 4x4. Were you able to find the cause of this fault?
    Thanks
  5. Jun 21, 2019 at 6:38 PM
    2010PreRunnerAZ
    2010PreRunnerAZ New Member
    Hi JediYoda today my 2010 has the same issue you described. Did you determine the issue?
    Thanks!
