RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Nov 19, 2021 at 10:48 AM
    #2001
    Crosbaugh
    Crosbaugh Well-Known Member
    And you didn't run into any issues when you mounted the cap with your rails being 1/8 in. off?
    EDIT: Rough Country look to mount in the same manner as the ones from Victory 4x4. I want to say someone in this thread ran into an issue with the rail being moved, but now I'm not sure and don't want to go through 101 pages.
  2. Nov 19, 2021 at 12:22 PM
    #2002
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Did you place the rubber squares near the bolt that holds down the cap?, without those rubber blocks you will bend stuff...
  3. Nov 19, 2021 at 1:57 PM
    #2003
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    Curious, did the 1/4-20 bolts you got from t-nutz fit into the smartcap channels? Or did you have to use M8s with the provided square nuts?
    Relyk711 likes this.
  4. Nov 19, 2021 at 5:28 PM
    #2004
    VinhVuPham
    VinhVuPham Well-Known Member
    Vinh
    2021 Army Green TRD Off-road Tacoma
    Stock
    Nope tight fit but should clear. I got the rubber end caps in case they run against the panel. But it clears
  5. Nov 19, 2021 at 5:44 PM
    #2005
    GoldenTaco27
    GoldenTaco27 Well-Known Member
    Blake
    Long Beach Ca
    2017 Tacoma DCSB TRD Off Road
    @hungoverland on IG, King 2.5" EXT Travel w/ Archive Garage shock relocation, Icon RXT leafpack, 285 Nitto M/T's, bronze Raceline Defender wheels, TJM front/rear bumpers, TJM Sliders, Prinsu Cabrac, Katzkin leather, RSI Smartcap EVO topper, OV Tuned, MESO everything, Spyder headlights and tail lights, center mounted infant restraining system (CMIRS) \m/
    I copied @Nick1992 and found that his part list worked out for me, but could be more snug. The 1/4-20's had a little play in them, so the M8's or anything slightly larger may be better.
  6. Nov 19, 2021 at 6:28 PM
    #2006
    PowerFlower
    PowerFlower Well-Known Member
    Southern Oregon
    2021 OR DCLB Army Green
  7. Nov 19, 2021 at 6:46 PM
    #2007
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Looks great man
    PowerFlower[QUOTED] likes this.
  8. Nov 22, 2021 at 7:34 AM
    #2008
    Crosbaugh
    Did anyone have issues torquing the bolts that hold the sides to the roof panel? 2 of the 10 appear to be free spinning. I can't tighten or loosen them.
  9. Nov 22, 2021 at 7:51 AM
    #2009
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    Crosbaugh likes this.
  10. Nov 22, 2021 at 8:54 AM
    #2010
    VinhVuPham
    Vinh
    Stock
    Dont torque to specs from RSI. I tighten the bolts by feels. IMO, I think you may have stripped the threading if the bolts dont want to back out or tighten. You might need to reach out to your vendor or RSI for new hardware.
    DAS Taco likes this.
  11. Nov 22, 2021 at 9:03 AM
    #2011
    Crosbaugh
    Good to know. I'm surprised this wasn't an issue with 8 of the 10 bolts.
  12. Nov 22, 2021 at 12:33 PM
    #2012
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    We have a few RSI Evo Sport (with side window) for the 2016+ 6ft bed caps in stock now! I also have 1 or 2 of the Evo Adventure (solid side panels that gullwing open) for the 2016+ 6ft bed caps in stock as well. If you're wanting one, grab them while they're in stock.
    Phone ---->>>> 888-466-8991
    Interwebs ---->>>> OFFROADALLIANCE.COM (Evo Sport) and OFFROADALLIANCE.COM (Evo Adventure)
    keygrip likes this.
  13. Nov 22, 2021 at 12:44 PM
    #2013
    TwinTaco31719
    Eric
    Glenbrook, NV
    That’s awesome. Love my rsi shell
  14. Nov 22, 2021 at 12:49 PM
    #2014
    DAS Taco
    DAS
    2017 TRD Offroad
    Me too!
  15. Nov 24, 2021 at 7:21 AM
    #2015
    r4nsom
    r4nsom Active Member
    Chad
    Everett, WA
    2020 Tacoma TRD OR
    This looks promising. I'd like to test something like this out. Would you be willing to share your design? I probably have those magnets on hand. What are you using for the gasket?
    DAS Taco and mindstar like this.
  16. Nov 24, 2021 at 7:55 AM
    #2016
    r4nsom
    Chad
    Everett, WA
    2020 Tacoma TRD OR
    Here are a few photos of my smartcap setup after getting it all wired up. The LEDs will turn on if any of the 3 smartcap doors are popped (via reed switch), or the tailgate is open (door jamb switch). LEDs can also be dimmed, or turned off completely if needed with the dimmer knob located in the DC panel. The DC panel is 3d printed, and contains one of those blue sea accessory panels. I removed one of the DC plugs and replaced it with an ARB threaded plug for the dometic fridge. The fridge is probably the coolest thing I own, nothing like pulling over for an ice cold seltz when i need one.
  17. Nov 24, 2021 at 8:07 AM
    #2017
    TwinTaco31719
    Eric
    Glenbrook, NV
    Dang that’s slick
  18. Nov 24, 2021 at 8:31 AM
    #2018
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    Dude, I saw when these hit IMGUR and commented on them there. Nice job. Have you invested in rubber trim yet for all the rough edges? It makes a huge difference.
  19. Nov 24, 2021 at 8:33 AM
    #2019
    r4nsom
    Chad
    Everett, WA
    2020 Tacoma TRD OR
    I haven't yet, and not sure what you're talking about. Can you show me an example?
  20. Nov 24, 2021 at 8:34 AM
    #2020
    i8boots
    UT - 801
