RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Feb 8, 2022 at 10:30 AM
    #2381
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    any issues with snow getting in the window?
  2. Feb 8, 2022 at 11:06 AM
    #2382
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Getting into the window and into the cab, or into the bed?
    Bed: snow does get in but I don’t really care about that, it’s actually pretty minimal but I’m usually just throwing snow gear back there on my way to/from the mountain so having snow dump in from outside isn’t a concern to me. The snow that gets in is just a little drift that just happens to blow in, or whatever might dump off the roof when I’m clearing off the truck if we had a heavier snow fall. I’m probably not the best person to ask, I’ve literally never closed that window and I’ve had the cap for 14 months now, dirt/rain/snow getting into the bed = zero fucks to me.
    Cab: yeah, I leave the window open so often that it’s not too uncommon that I forget to close it going into the cab and I’ve had rain/snow get in - it’s generally pretty minimal, but I have neoprene seat covers so I don’t care too much about that either. We live in a super dry high desert climate so the moisture generally isn’t a concern. By contrast I spent a few months in western oregon where it rains constantly and it was a battle to keep general moisture out, if the window was closed condensation formed inside and if it was open it rained in - that I didn’t care for. The only real issue I’ve had from leaving the cab window open is light snow getting into the track and then freezing, so when I get in the next morning and it’s cold AF, the window is frozen open and my kids get cold lol. It thaws out after about 15 minutes of driving around with the heater on. Why do I leave the window open in the winter so much? I like the fresh air, and if it’s snowing outside I have the defrost on hot to keep ice from forming on the windshield while I’m driving and to keep the cab from getting too hot that back window open creates the perfect mix of warm but fresh air in the cab.
    mrtonyd[QUOTED] likes this.
  3. Feb 8, 2022 at 11:16 AM
    #2383
    mrtonyd
    Tony
    Colorado
    i was more curious if snow got between the shell and the cab and blocked any vision.
    but why dont you get window visor things and you can leave the side windows open for fresh air without the risk of snow/moisture getting in?
  4. Feb 8, 2022 at 8:01 PM
    #2384
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Ride home from work, sun to the left of me slightly forward. Nothing added to rsi windows and nothing added to the rear cab window/slider. Good visibility for what’s there
    19C46A00-312D-4A7C-AC3A-31909C71E34D.jpg 9B067782-738A-4E54-BA18-0DE1FC5598CF.jpg
  5. Feb 9, 2022 at 11:35 PM
    #2385
    baldbeardedtaco
    FL
    The garmin mini2 and hardwire kit showed up today. Rear mounting it in the canopy. Need to look into switched power so I’ll either be pulling my 10awg harness out to add a single switched wire or find something near the rear
  6. Feb 10, 2022 at 12:35 AM
    #2386
    FishWolf
    FishWolf Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Wonder how the weight of these compares to a fiberglass unit like Leer etc
  7. Feb 10, 2022 at 12:47 AM
    #2387
    baldbeardedtaco
    FL
    Same, roughly 180
  8. Feb 10, 2022 at 5:47 AM
    #2388
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    Yes, that can happen, mostly if I am not careful when removing the snow in the morning and push it into the gap.
  9. Feb 10, 2022 at 6:22 AM
    #2389
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    Still looking for someone to swap a sliding door with. My evo adventure molle for your sliding window. Southwest area. Will kick you some cash to sweeten the deal
  10. Feb 11, 2022 at 11:25 AM
    #2390
    minium
    Pretty much this, for the most part it hasn’t been an issue.
  11. Feb 15, 2022 at 8:07 PM
    #2391
    RusD
    RusD Active Member
    2017 QS DCSB OR Tacoma
    Can you, or anyone else with the same setup, confirm that the two slimline racks sit level with one another? I had the full Dissent Offroad setup and sadly it doesn't look like I will be able to modify the top of the bed rack to fit the RSI. So now I'm chasing the rabbit hole of backup options. Tempted to keep the Dissent cab rack and just get some load bars, but dang it I like a platform's functionality.
  12. Feb 16, 2022 at 8:15 AM
    #2392
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    What are those things on the back seat headrests?
  13. Feb 16, 2022 at 11:10 AM
    #2393
    baldbeardedtaco
    FL
    To have a place for my girls to rest their head instead of flopping like a fish. You asking for a name or brand? Or purpose
  14. Feb 16, 2022 at 11:20 AM
    #2394
    Temutaco
    Temutaco First trip 10/31/2021
    Bay area, California
    2021 Tacoma TRD Off-Road DC LB
    Toyota TRD 3" lift Rago Bed Stiffeners
  15. Feb 16, 2022 at 3:25 PM
    #2395
    baldbeardedtaco
    FL
  16. Feb 16, 2022 at 8:16 PM
    #2396
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    Received an email from CapWorld that my EvoA for 2nd gen will arrive in the USA by the end of the month. Christmas in March!!:fingerscrossed:
    Vmax88 and minium like this.
  17. Feb 17, 2022 at 10:44 AM
    #2397
    VitoVegas
    VitoVegas Professional Paint Slinger
    Vito
    Illinois
    2018 Black Tacoma TRD Sport
    I just killed 3/4 of my work day at the office reading and catching up on all 120 pages. Decided it was time to make an account and have my first post being a shoutout to everyone with the great insight. Thank You All. I got my eye on a local one for sale. Hopefully it pans out, but for sure picking one up in the near future.
    PaulDuB, BassAckwards, GGut and 3 others like this.
  18. Feb 17, 2022 at 10:46 AM
    #2398
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    Good luck on acquiring your cap.
    VitoVegas[QUOTED] likes this.
  19. Feb 17, 2022 at 1:40 PM
    #2399
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Its roughly the same but these caps can be taken apart which is a huge upside from Leer or ARE caps which come as one giant piece.
  20. Feb 17, 2022 at 1:44 PM
    #2400
    OffroadAlliance.com
    Brockton, MA
    2018 Tacoma TRD Pro
    If you don't end up finding any locally in the coming months, feel free to reach out our way. We have shipments coming in periodically but they come in from South Africa so it's all up to when containers can get into the shipping ports.
