RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Feb 24, 2022 at 12:16 PM
    #2441
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Why does it look like the cap is 1" too short in that video. A lot of the top of the tailgate is visible.
  2. Feb 24, 2022 at 1:23 PM
    #2442
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Normal
  3. Feb 24, 2022 at 4:58 PM
    #2443
    DrewDown
    DrewDown Well-Known Member
    Tucson, AZ
    2014 Double Cab Short Bed
    Purchased from @OffroadAlliance.com
    It was delivered today
    OffroadAlliance.com likes this.
  4. Feb 24, 2022 at 5:18 PM
    #2444
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Awesome! Would love to see some photos after it’s installed.
  5. Feb 25, 2022 at 8:57 AM
    #2445
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    It’s supposed to be, the cap aligns with the lines on the tailgate:
    https://i.imgur.com/k4GKjKN.jpg
  6. Feb 25, 2022 at 9:34 AM
    #2446
    VitoVegas
    VitoVegas Professional Paint Slinger
    Vito
    Illinois
    2018 Black Tacoma TRD Sport
    Looks like this is going to have to be my move. Local buyer sold it before I had a chance to get up there.
  7. Feb 25, 2022 at 9:35 AM
    #2447
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    They are pretty popular. Good reason to build a Stateside factory.
    VitoVegas[QUOTED] likes this.
  8. Feb 26, 2022 at 5:59 AM
    #2448
    nglescobar1992
    nglescobar1992 Well-Known Member
    boogers
    2019 tacoma
    oem
    Has anybody had any success with removing scratches from the Rsi cap
  9. Feb 26, 2022 at 7:03 AM
    #2449
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    I've only ever seen one other SmartCap in the wild, but get questions on mine all the time, mainly "is it worth the price?" My usual response is something like "hell yeah, except these dollar store latches."
    Vmax88 likes this.
  10. Feb 26, 2022 at 5:49 PM
    #2450
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    That’s tough for a matte finish. Likely any traditional/standard method will make it noticeably worse. You rub the same spot enough and you’ll make it shiny. When I was reading up on matte paint care the only true option is a repaint. If I had to do that then I’d think hard about Bedliner sprayed on
  11. Feb 26, 2022 at 5:56 PM
    #2451
    baldbeardedtaco
    FL
    I didn’t use that as my guide (never seen it mentioned)- the gap between bed box and cab is what I followed up to canopy and cab for the cleanest line.
  12. Feb 26, 2022 at 7:23 PM
    #2452
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    I’m assuming this will be less of an issue with the 2nd Gen since the tailgate does not have a rounded upper edge. Now that the 2nd Gen is out and being installed, can anyone with a 2G Evo please post pics of that aspect?
  13. Feb 26, 2022 at 10:51 PM
    #2453
    minium
    I bought the shell from a shop locally that was offering free install, when I picked it up I noticed a weird gap from the bed to the cab, the hatch was about centered on the tailgate. I felt around on the inside and noticed a lip against the back of the bed (toward the cab) and there was a gap on that lip. I loosened the C clamps and slid the cap back flush to the lip against the back of the bed….. that’s when I noticed that the hatch then lined up perfect w/ that curved line on the tailgate so I figured it was supposed to be that way. It also allows the tailgate to close a little easier w/ the way the seal now presses up against it. I can open/close the tailgate easier without opening the back hatch. I also like how there is much less gap from cab to cap.
    Probably very likely since the 3rd gen has that rear camera hump (at least I assumed that’s why it has that weird upper edge).
    GlennHaggis[QUOTED] likes this.
  14. Feb 26, 2022 at 11:19 PM
    #2454
    BudFriendguy
    Zak
    Do you have pics of the fitment you're talking about?
  15. Feb 27, 2022 at 7:45 AM
    #2455
    Ricky2times
    Ricky2times Member
    Oregon
    2022 TRD OR
    Anyone finding a need or benefit to adding bed strengtheners once you install your Smartcap. I am getting do it/no need to add from a dealer expending which employee I speak to.
    OmahTako likes this.
  16. Feb 27, 2022 at 7:52 AM
    #2456
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    You’re adding weight to the bedsides, but very little. You may also add a rack for a RTT, carry kayaks, maybe an awning and additional fuel/water in RotoPax. The dynamic weight limit is what your bedsides can tolerate. Stiffeners are added insurance so your bed walls don’t end up askew.
    Ricky2times[QUOTED] likes this.
  17. Feb 27, 2022 at 7:55 AM
    #2457
    BudFriendguy
    Zak
    I added some before the cap to avoid any problems down the line and give peace of mind.
    This week I noticed the tailgate had a very bad/uneven gap on each side. Not sure if this was misaligned before stiffeners to be honest, but I'd imagine so since the stiffeners are pretty solid.
  18. Feb 27, 2022 at 8:14 AM
    #2458
    Maxx
    Maxx Well-Known Member
    Bed stiffeners are recommended for anyone adding a topper to their Tacoma. When I installed mine before the topper, it squared up my bed sides that I didn’t realize were slightly off. The added tie down point have been nice too. If your dropping topper money, it’s well worth the small investment.
  19. Feb 27, 2022 at 8:21 AM
    #2459
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    I absolutely would, whether you’re going to put a tent on top of your cap or not.
    Ricky2times[QUOTED] and OmahTako like this.
  20. Feb 27, 2022 at 12:18 PM
    #2460
    Ricky2times
    Ricky2times Member
    Oregon
    2022 TRD OR
    Thanks gents. That is exactly the information I needed.
