RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Feb 28, 2022 at 3:49 PM
    #2461
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Yup, just went and snagged one.... this is the driver side corner against the back of the bed where it meets the cab..... it has the angled lip that sticks out, and the part circled in purple with my wonderful drawing skills is the lip that had a 1/2 - 1 inch gap when I picked up the truck. I just loosened the clamps and slid it back flush. That is when I noticed the tailgate portion lined up perfectly with that curve.
    BudFriendguy[QUOTED] likes this.
  2. Feb 28, 2022 at 4:31 PM
    #2462
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    lining up with the interior as opposed to the exterior is a unique approach if that is what the cap designer intended. To me, it appears short and it seems like simply adding a couple inches to the end cap (on either end) would make it appear more fitted. My $0.02 and worth what you paid.
  3. Feb 28, 2022 at 4:35 PM
    #2463
    minium
    Hah, yeah I agree completely, actually. I guess their logic is to fit that lip to the 3 bed sides, and the tailgate portion would then just line up (except each of my bed sides has a gap in some spots and flush in others, maybe that’s a sign for bed stiffeners?).
    If I could change anything, it would actually be to make it a couple inches taller, I don’t see a lot of reason for it to match the roof line and having a little more overhead room inside would come in handy. Creating sloped angles on the outside also reduces inside dimensions. It would probably just add to the utilitarian look that it already achieves.
  4. Feb 28, 2022 at 4:44 PM
    #2464
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    2nd Gen caps finally coming in. We have a couple left for Free Installation if anyone wants one.
    minium likes this.
  5. Feb 28, 2022 at 4:53 PM
    #2465
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Only the short bed seems to have the issue of appearing stubby. My long bed model fits very nicely, although I will be checking the inner alignment now based off the pic @minium when I get the chance.
  6. Mar 1, 2022 at 6:15 AM
    #2466
    DrewDown
    DrewDown Well-Known Member
    Tucson, AZ
    2014 Double Cab Short Bed
    Got my second gen cap installed. Very happy with it.
  7. Mar 1, 2022 at 6:18 AM
    #2467
    DrewDown
    Tucson, AZ
    Any tips on the lowest profile way of mounting my RTT?
  8. Mar 1, 2022 at 9:42 AM
    #2468
    Goochwarmer
    Goochwarmer Well-Known Member
    2017 Tacoma TRD Off Road MT
    Hard to get photo but you can see the shrader valve is on top and the lower right you can see the electrical tape (tire 1), I also put papertowel in the gap as it's not 100%. But I could reach back into the cooler and in the winter I can open the window and defrost the back a bit if needed. Wrapped the bottom 1/3 in electrical tape so it fits snugly at the bed/cab interface but doesn't stop the window from open/closse and the top part is expanded to keep 'most' of the snow/rain out (tire 2).
  9. Mar 1, 2022 at 8:04 PM
    #2469
    jbiscuit
    jbiscuit Well-Known Member
    Jake
    Portland
    2021 LR Pro
    brilliant
    Goochwarmer[QUOTED] likes this.
  10. Mar 1, 2022 at 8:20 PM
    #2470
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
  11. Mar 2, 2022 at 1:22 AM
    #2471
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    Man, that sure looks sick! Still waiting on mine. Should be here soon.:fingerscrossed: Just as I expected, the rear hatch lines up much better since the 2nd Gen has a straight profile tailgate. Very clean overland look with the EvoA!
    4xThad, DrewDown[QUOTED] and minium like this.
  12. Mar 2, 2022 at 1:24 AM
    #2472
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    Don't put it on your cap. :cheers: Seriously thought about the best way to install a RTT to not adversely impact mileage and that would be a low profile rack the "hides" the RTT behind the cab.
  13. Mar 2, 2022 at 6:03 AM
    #2473
    DrewDown
    Tucson, AZ
    thats what I’m just switching from haha
  14. Mar 2, 2022 at 6:22 AM
    #2474
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    Oops! Well, your RTT is aerodynamic.
    DrewDown[QUOTED] likes this.
  15. Mar 2, 2022 at 7:22 AM
    #2475
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    You can make a low profile rack very easy using Smartcap track nuts if you’re interested I can send you pictures.
  16. Mar 2, 2022 at 8:21 AM
    #2476
    Sam239
    Sam239 Well-Known Member
    Samuel
    2008 Tacoma
    Do you have a heavy duty leaf pack ?
  17. Mar 2, 2022 at 8:23 AM
    #2477
    DrewDown
    Tucson, AZ
    definitively interested. Thanks
    OmahTako[QUOTED] likes this.
  18. Mar 2, 2022 at 8:23 AM
    #2478
    DrewDown
    Tucson, AZ
    Yes I do. I have an all-pro leaf pack.
    Sam239[QUOTED] likes this.
  19. Mar 2, 2022 at 8:26 AM
    #2479
    Sam239
    Samuel
    2008 Tacoma
    My RSI is coming in probably early next week, not sure if it’s gonna make my rear end sag or not without one but I guess we shall see.
  20. Mar 2, 2022 at 9:39 AM
    #2480
    minium
    Are you otherwise stock? I would get a set of SummoSprings for $200, takes 20 minutes to install them. If you haven’t heard of them before, they are just foam core bump stop replacements but it takes the initial sag out and maintains stock ride height when you have a little extra weight in the back (similar to airbags without the hassle of air or leaks).
