RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Mar 13, 2022 at 10:50 AM
    #2541
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    i would chose Alu-cab for weight.
    i'd chose RSI for windows and diy installation.
    i'd chose RLD for structural integrity (fewer seams and fewer reports of leaky windows).
    i will most likely end up purchasing whichever one implements (and makes readily deliverable) an improved latching mechanism first.
    SR-71A likes this.
  2. Mar 13, 2022 at 11:04 AM
    #2542
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    thats awesome news!!!!
  3. Mar 13, 2022 at 11:08 AM
    #2543
    GOROAM
    19 TRDOR
    Crawling Malls
    RLD comes with windows, that don’t leak…I’ve used my RLD all winter from Utah to Yellowstone, through Montana, Washington, Oregon and had zero issues with locks or latches. The RLD has a gutter system on the outside edge that directs water outboard, and after using RTV silicone on the forward edges (the known intrusion spot on Tacoma’s), it’s been water, dust proof.
  4. Mar 13, 2022 at 5:07 PM
    #2544
    D. Lengua
    '21 Limited LB
    again, from what i've read here and elsewhere, RLD owners seem less likely to report leaks from seams and windows. the latches seem to be equally subject to freezing across the 3 makes, and i live in the Northeast so that's a concern for me. but i also have a 6' bed and foresee sleeping under the canopy, so i'd like to see a solution for opening/closing from the inside. RLD and RSI have been promising a new latching mechanism for a long time now. we'll see....
  5. Mar 13, 2022 at 5:38 PM
    #2545
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Well I don't have leaky windows in fact I have no leaks at all unless I'm forcing water into the bed of my truck through the cracks in orfices that came from Toyota. My cap is watertight itself. I could care less but latches I don't sleep in it. But the covers for the latches and now they are perfect. So for me works out great. Far and exceeds anything fiberglass I've ever owned. The new ones I've seen now are poorly made and the same cost so it doesn't make sense to me.
  6. Mar 14, 2022 at 6:16 AM
    #2546
    Sickoreo
    Sickoreo Well-Known Member
    21' DCSB OR
    All I reached out to RSI to get an update on the locks and below is what I got from them.
    "Unfortunately, I don't have good news for you as the locks have once again been delayed further with no new ETA being provided as yet. I know this is not the news you want to hear but all I can provide at this point in time. "
    OmahTako and D. Lengua like this.
  7. Mar 14, 2022 at 7:51 PM
    #2547
    Ragsdaddy47
    Ragsdaddy47 New Member
    Austin
    2015 Off Road (aka money pit)
    20220314_181651.jpg 20220314_180534.jpg 20220314_180727.jpg 20220314_181557.jpg 20220314_180749.jpg First impression of the RSI: the stoke is high. 2nd gen has my heart
    codyjphoto, Road_Warrior and Temutaco like this.
  8. Mar 15, 2022 at 2:53 AM
    #2548
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    If I recall correctly, my issue with the driver’s side light being out maybe a cap brake light harness issue?
    Without re-reading the thread from the start, could someone please confirm?
    @OffroadAlliance.com
    I just noticed this last weekend…
    Thank you!
  9. Mar 15, 2022 at 8:42 AM
    #2549
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    I spoke with our contact as RSI. Here's what he thinks:
    You would need to check the brake light harness to see if it is missing a wire from the 3 pin plug. This was an old issue with the harnesses but was rectified early in 2021 already.
    Although we don't know when you bought your cap, this is most likely the case with the harness you have. You would just need to confirm for me and RSI can get a new harness sent out to you no problem.
    The red arrow in the image below shows the missing wire in the 3 pin plug.
    I'll send you a PM with the contact info for our RSI guy.
  10. Mar 15, 2022 at 4:39 PM
    #2550
    GGut
    GGut Member
    Gabe
    2020 White Sport
    I was hoping someone might be able to tell me width of the rails on top of the EVOa short bed before I start scrolling the 100+ pages for the 6th or 7th time. hahaha thanks !!
    Looking to buy some of these before the smart cap arrives and wanna make sure I don't get anything too short:
    https://www.tnutz.com/product/ex-1020-black/
    Thanks again
    OmahTako likes this.
  11. Mar 15, 2022 at 4:52 PM
    #2551
    Ragsdaddy47
    Austin
    @GGut
    Furthest front (towards cab) measurement: outside to outside of rail is 43".
    Furthest back (towards tailgate) measurement: outside to outside of rail 41 3/4"
  12. Mar 15, 2022 at 4:56 PM
    #2552
    GGut
    GGut Member
    Gabe
    2020 White Sport
    Thanks!
  13. Mar 15, 2022 at 5:42 PM
    #2553
    OmahTako
    SoCal
    You can cut it yourself if you want to buy a stock length. Just get a aluminum blade for your cut off saw. Works fantastic. That's what I did.
    GGut[QUOTED] likes this.
  14. Mar 15, 2022 at 6:13 PM
    #2554
    OZ TRD
    Central Coast CA
    Thank you!
    - This is the case. I will follow-up with Lionel.
    Thanks again
  15. Mar 15, 2022 at 8:32 PM
    #2555
    vtac
    vtac Well-Known Member
    2017 Tacoma TRD OR DCSB
    anyone have alucab load bars with the 60mm feet on them? want to see how it looks. I went with the higher feet to clear the prinsu cab rack when I put on my RTT.
  16. Mar 15, 2022 at 8:50 PM
    #2556
    OmahTako
    SoCal
    Lionel Is good people. He'll get it sorted.
    Vmax88 likes this.
  17. Mar 18, 2022 at 6:49 AM
    #2557
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
  18. Mar 20, 2022 at 3:00 PM
    #2558
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    Just swapped side panels with a long bed (I have a shortbed) if anyone was wondering about fitment. Direct swap
    Vmax88, Goochwarmer and D. Lengua like this.
  19. Mar 20, 2022 at 3:05 PM
    #2559
    D. Lengua
    '21 Limited LB
    what made you decide to put it on the driver's side?
  20. Mar 20, 2022 at 3:09 PM
    #2560
    TacoNoVeggies
    TacoNoVeggies Well-Known Member
    San Diego, CA
    '20 Off Road ACLB Quicksand
    Stock
    So, what changed? What was the benefit for switching (both for you and the person with the long bed)?
