RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. May 12, 2023 at 9:59 PM
    #3321
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mounts Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Mishimoto Radiator MMRAD-TAC-16 Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
    Less than a week with my SmartCap and just discovered that the new redesigned sliding glass windows on both side panels can easily be opened even when "locked" simply by pushing in on them with very little force. Happened while I was washing my truck.
    To say I'm pissed is an understatement. Why did I spend a premium on a cap that is totally unsecured?
    P8trit, sbx22 and Bertw192 like this.
  2. May 12, 2023 at 10:25 PM
    #3322
    ET_Quila
    ET_Quila Well-Known Member
    ET
    Ohio
    2033 4Runner Trd Off Road
    Well that's not good. Is this something you can easily replicate or was it just a one time thing? I have a cap on order and hope this isn't systemic.
    msgs350 and Bertw192 like this.
  3. May 12, 2023 at 10:37 PM
    #3323
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @Mike's Custom Toys?
    My cap is stuck in shipping purgatory, but this has me a bit concerned.
  4. May 12, 2023 at 10:39 PM
    #3324
    StinkFu
    Pacific Northwest
    Unfortunately, I was able to replicate it easily for about an hour along with my 15 year old nephew. No matter how I closed and "locked" the windows.
    I will post a video of it tomorrow after I calm down a bit.
    Temutaco and msgs350 like this.
  5. May 13, 2023 at 5:55 AM
    #3325
    Jazzy
    Jazzy Member
    Kevin
    South Dakota
    2022 Tacoma TRD Pro Grey
    Modifications underway
    That stinks for sure and is way less than ideal. A sign that a new design was rushed. It's likely the previous designs they have done never had the issue or they would have had a test to catch it.
    If it is that bad and systemic they should come up with a fix for it and some kind of retrofit process. Doesn't help you at the moment but will give you some help in the future.
    Your dealer Mike will know now of course, but call RSI customer support and send them the video too, that should speed up a fix for them. I'm guessing they are so swamped with orders any info you can give them directly will help the process. And hearing it from multiple sources will let them know the gravity of the situation.
  6. May 13, 2023 at 8:21 AM
    #3326
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    Ok I will follow up with them on Monday
  7. May 13, 2023 at 8:23 AM
    #3327
    Mike's Custom Toys
    Grants Pass, OR
    I reached out to RSI and they have a bunch of new instruction videos coming out. I will try to get access to all the Tacoma ones.
    https://vimeo.com/manage/videos/817754235/d08e545027
  8. May 13, 2023 at 10:11 AM
    #3328
    Maxx
    Maxx Well-Known Member
    I have one of the early model EVOa’s produced in South Africa. It’s been on for about a year and half and it’s been solid. No leaks that I have come across. I’m actually going to remove the filter up top in the next week for maintenance and see what it looks like.
  9. May 13, 2023 at 12:07 PM
    #3329
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    Woahh woahh woahh - Get in line!
    No complaining about the new windows not locking until RSI address those of us with old locks that freeze and can’t be opened from the inside.
    Told for over a year retrofit locks would be engineered and make available. Been patiently waiting on their “list”
  10. May 13, 2023 at 1:15 PM
    #3330
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Sucks that you’re having issues, but the video title is misleading. I don’t have any issues with my RSI cap. I hope RSI helps you out tho.
    Naveronski likes this.
  11. May 13, 2023 at 2:13 PM
    #3331
    ET_Quila
    ET
    Ohio
    That is not a well thought out design, but maybe RSI will have a quick solution for this. I am waiting on delivery of mine as well.
  12. May 15, 2023 at 5:57 AM
    #3332
    lil gelato
    lil gelato Well-Known Member
    Frustrating. Every time I get close to placing an order for an Evo Sport another issue pops up that keeps me from clicking.
    Are there any other 3rd gen cap owners experiencing the same issue with the sliding window opening when "locked"?
    D. Lengua likes this.
  13. May 15, 2023 at 9:45 AM
    #3333
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Should have gotten in on the first gen. Still loving mine so far. Not being able to open it from the inside isn't ideal but I have a 5' bed and was never planning on sleeping in mine.
    Tacodog, OZ TRD and GoldenTaco27 like this.
  14. May 15, 2023 at 9:47 AM
    #3334
    chuam
    Marcus
    San Diego
    That isn't ok in any sense. That's a pretty bad design error.
  15. May 15, 2023 at 11:21 AM
    #3335
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Pallet finally landed at my local freight center. No need to follow up, assuming you haven't already.
    Thanks!
  16. May 15, 2023 at 12:31 PM
    #3336
    Mike's Custom Toys
    Grants Pass, OR
    Great news. I was stuck in a phone tree
    Bertw192[QUOTED] likes this.
  17. May 15, 2023 at 12:57 PM
    #3337
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It's weird, because the tracking still shows "departed Portland on 5/3"
  18. May 15, 2023 at 1:32 PM
    #3338
    StinkFu
    Pacific Northwest
    Mike and Dan at Mike's Custom Toys and RSI have gone above and beyond to get this addressed and they already have a fix for the issue to prevent it happening on more doors and are sending me replacement doors. Outstanding customer support on this.
    Ren710, RDT415, D.A.S. Taco and 4 others like this.
  19. May 15, 2023 at 2:23 PM
    #3339
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    Now I'm sad I didn't watch the video earlier today when it was still up. Glad that Mike and Dan were able to jump on this!
    StinkFu[QUOTED] likes this.
  20. May 16, 2023 at 6:17 AM
    #3340
    lil gelato
    Happy to hear. Can you elaborate on the fix?
