RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Jun 7, 2023 at 9:14 AM
    #3441
    Tarpon Slayer
    Tarpon Slayer Well-Known Member
    Tacoma TRD Pro
    RSI Smart Cap / Inspired Overland Tent
    FWIW I'm putting Fishbone stiffeners on the front and some Extreme Terrain low profiles on the tail so I can still use a drawer system. Thought better safe than sorry, and Fishbone confirmed that it will work with RSI as long as you have a track system.
    Now to just get that cap...
  2. Jun 7, 2023 at 12:15 PM
    #3442
    P8trit
    P8trit Well-Known Member
    Have a link to low profile?
  3. Jun 7, 2023 at 12:23 PM
    #3443
    Tarpon Slayer
    Tacoma TRD Pro
  4. Jun 7, 2023 at 12:25 PM
    #3444
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
  5. Jun 7, 2023 at 12:25 PM
    #3445
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  6. Jun 7, 2023 at 12:27 PM
    #3446
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Total Chaos stiffeners have an extremely small gusset. They’re a structurally inferior design to pretty much every other option.
    OZ TRD likes this.
  7. Jun 7, 2023 at 12:31 PM
    #3447
    mrtonyd
    Tony
    Colorado
    well thats a bummer since i just got the total chaos ones. but they look like the mounting holes are the same so i should be able to swap them if i want i guess
  8. Jun 7, 2023 at 2:05 PM
    #3448
    Naveronski
    Fort Worth
    Which is interesting to think about - do you know of any testing to compare the different brands?
    For example, if you were to bolt each variant of stiffener into a jig that mimics their installation in a Tacoma bed, and "pulled" from the same spot at the top of each, which would fail at what force?
    Further, is that force reasonable?
    Does it matter if one brand is 1.3x stronger than another, when both are stronger than any force the truck would experience?
    If the only force that would cause a stiffener to fail would also be catastrophic to the truck itself, does the 1.3x stronger difference really matter?
  9. Jun 7, 2023 at 3:52 PM
    #3449
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    None will 'fail'. :deadhorse:- Unless its due to a collision, or something out of normal driving.
    The issue is how well do they do their job - of being stiff - to prevent flex. TC bed stiffeners are not as 'Stiff' as others... Their construction will allow more flex than many others' designs. You'll see cracks before any stiffener 'fails'.
    How much flex is OK? I dunno. I'd stick to the theory that less flex is better than more.
    I have a cap; but do not carry any significant weight otherwise. I do not believe it is a major issue in any case... Beds are not 'failing' as Tacos go down the trail... - Mostly.
    I like the additional attachment points on mine.
    Cetacean Sensation likes this.
  10. Jun 7, 2023 at 4:19 PM
    #3450
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    :boink: Got the data for comparison?
  11. Jun 7, 2023 at 4:24 PM
    #3451
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    We've got just a few Evo Sport 5ft bed caps left in stock and another dozen arriving in the next few days. This is likely the last of the 5ft Evo Sports until October! If you're wanting one of the new caps, grab them while they're available.
    Interwebs ---->>>> OFFROADALLIANCE.COM
    Vmax88 likes this.
  12. Jun 7, 2023 at 5:16 PM
    #3452
    Cetacean Sensation
    PNW
    Yeah i think most companies put them in the same place to clear the bed structure and taillight bits.
    This isn't really a thing that requires testing. It's just a matter of physics.
    Looking at comparable designs, it's more than 1.3x difference between the TC stiffeners and others on the market. For the application, stiffer is better. I'd buy an option with a beefy gusset if I were to pick up a topper or bed bars.
    Sure.
    99% of aftermarket parts are fabbed from either a basic carbon steel (like A36) or a general use stainless steel (like 304). All commonly available and commercially used steel alloys have similar enough material properties that the performance of a part like this comes down almost exclusively to its design.
    The majority of the strength in bending for a corner bracket comes down the size of its gusset. Simply put, bigger gusset = more stiff. Total Chaos has one of the smallest gussets of the available stiffener brackets, it's very small. With every thing else about material properties known, we can say the TC design is inferior to others on the market that use larger or multiple gussets.
    D.A.S. Taco and OZ TRD like this.
  13. Jun 7, 2023 at 5:23 PM
    #3453
    msgs350
    PNW
    Some Mods
    until I see one these stuffies separate/fail due to welds, gussets…or testing results from an actual lab (that does this and I doubt any will), I’m gonna be an “ass” and assume they are fairly equal. Happy to be proven wrong tho.
    P8trit, D. Lengua and Naveronski like this.
  14. Jun 7, 2023 at 5:26 PM
    #3454
    Cetacean Sensation
    PNW
    You're wrong. But sure; you do you.
  15. Jun 7, 2023 at 5:26 PM
    #3455
    msgs350
    PNW
    Some Mods
    ok, yes. I will. Thanks for your expertise here.
  16. Jun 7, 2023 at 5:37 PM
    #3456
    Naveronski
    Fort Worth
    That’s an awful lot of assumptions made… and saying “it’s just a matter physics”, yeah guy - physics involves testing and experiments. :rolleyes:
    D. Lengua and msgs350 like this.
  17. Jun 7, 2023 at 5:45 PM
    #3457
    msgs350
    PNW
    Some Mods
    Stop it! Who need testing when you can just look at it?!! :rofl:
    OZ TRD likes this.
  18. Jun 7, 2023 at 5:46 PM
    #3458
    Cetacean Sensation
    PNW
    Physics is math. Materials science isn’t assumptions. It’s all known quantities. All of these properties are listed in engineering tables.
    BoomerGVNG likes this.
  19. Jun 7, 2023 at 5:53 PM
    #3459
    Cetacean Sensation
    PNW
  20. Jun 7, 2023 at 5:56 PM
    #3460
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Is this a follow the science scenario?:rolleyes::rolleyes:
