RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Feb 23, 2024 at 4:15 AM
    #3901
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    Interesting you mention it...I've noticed that mine differs from some of the ones I see here. What are the differences (aside from the latches). I also noticed it attaches to the truck via a different method. No c-clamps, just rail blocks and bolts.
  2. Feb 23, 2024 at 7:23 AM
    #3902
    JSX
    JSX Member
    Eastern Washington
    Curious how these are sealed against water getting in to the cavity now, do you have a pic with the latch open?
    D. Lengua likes this.
  3. Feb 23, 2024 at 8:35 AM
    #3903
    Sickoreo
    Sickoreo Well-Known Member
    21' DCSB OR
    Since customers are getting the new latches with current orders I sent an email to RSI warranty email inquiring about latches for older models and here was the response I got.
  4. Feb 23, 2024 at 8:48 AM
    #3904
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    The new latches in theory are nice but they don’t latch easy like the older style. Really gotta push hard to hear that click, and yes they’re all adjusted properly. The other thing is when you put the key in to lock them, if you push the key in anymore then necessary it will pop the latch open.
    Cetacean Sensation and Sickoreo like this.
  5. Feb 23, 2024 at 8:51 AM
    #3905
    lil gelato
    lil gelato Well-Known Member
    @tacotrdyota Can the new latches be opened from the inside when locked from the outside?
  6. Feb 23, 2024 at 9:07 AM
    #3906
    tacotrdyota
    Kevin
    That I don’t know. I will see when I get in. I imagine they would. The lick just prevents the push button from being pushed. It doesn’t seem like it would affect the inside release. But the handle/latch is a lever so maybe not.
  7. Feb 23, 2024 at 9:10 AM
    #3907
    TacoPacific
    TacoPacific Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    I built mine; and re-torque Spring and Fall. Sometimes there is no change; sometimes it is considerable.
  8. Feb 23, 2024 at 9:16 AM
    #3908
    tacotrdyota
    Kevin
    I torqued mine about 5 times yesterday. The foam settles and then 20 min later they tightened more.
  9. Feb 23, 2024 at 9:40 AM
    #3909
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    Yes they can be released from the inside
  10. Feb 23, 2024 at 10:29 AM
    #3910
    lil gelato
    I know the new latches open from the inside. I'm under the impression that this was the main reason for the redesign. I am curious if the lock status affects opening from the inside. i.e.- smash window and open hatch using interior buttons to gain easy access to entire bed vs smash window and have to remove items through broken window. I realize this issue would only apply to the EVO sport as the rear glass of the adventure cap can be protected with security mesh.
  11. Feb 23, 2024 at 11:04 AM
    #3911
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    The ability to open from the inside is desirable when you are fiddling around inside and you need an open hatch - especially if you are sleeping inside. Not having to crawl outside to open the latches is a great addition.
    My arms are long enough that I can open them from the little window, if needed... But it takes a bit of a reach. I usually crawl out.
    In reality, once you break a window you pretty much have full access. I do not see much disadvantage. Any thieving Sh*t will mash & grab fast to make a run for it. I don't any of them will stop to ponder whether the latches can be undone from the inside.
    Prying the hatches open is much discreet & quieter than a window smash. I'd do that before breaking a window... a small breaker bar will overpower the latches on any topper (If I were a thiving sh*t, that is...). Even solid hatches, or ones with security mesh can be defeated fairly easily in reality...
    As it is often mentioned here; if someone wants it, they will take it. It is the unfortunate truth. I live in a pretty quiet area where people are pretty cool, fortunately. But when traveling through certain more urban areas, I often have a second look around if I have to leave the taco...
  12. Feb 23, 2024 at 11:18 AM
    #3912
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Do the locks open from the inside when locked? Or do they have to be unlocked?
    lil gelato likes this.
  13. Feb 23, 2024 at 11:18 AM
    #3913
    lil gelato
    I agree that with time and determination most anti-theft devices can be bypassed. However, the support frame/tracks inside the side windows would prevent large objects from being removed easily. Thieves try and move quick and if extra effort is required, they might just bail and move onto the next target.
  14. Feb 23, 2024 at 11:19 AM
    #3914
    lil gelato
    yes, this is my question
  15. Feb 23, 2024 at 12:38 PM
    #3915
    TacoPacific
    Vancouver BC
    This is :fingerscrossed:… once the RTT and Awning go on I assume they will at least weigh it down. :rofl:
  16. Feb 23, 2024 at 4:25 PM
    #3916
    tacotrdyota
    Kevin
    When locked from the outside you can open from the inside release.
    lil gelato[QUOTED] likes this.
  17. Feb 23, 2024 at 4:27 PM
    #3917
    tacotrdyota
    Kevin
  18. Feb 26, 2024 at 2:45 PM
    #3918
    tacotrdyota
    Kevin
    @Mike's Custom Toys, on the back hatch on the inside around the glass there’s nutserts, does that mean I can get security screen for it now?
  19. Feb 26, 2024 at 2:56 PM
    #3919
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    @tacotrdyota
    Yes, they offer security screens for them now (Sport and Adventure models).
    tacotrdyota likes this.
  20. Feb 26, 2024 at 3:53 PM
    #3920
    TacoPacific
    Vancouver BC
    Oh man!! That would be super awesome!!! Will they be available; or are they available for existing owners now?
