RSI Smart Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 4, 2020.
  1. Mar 27, 2021 at 5:13 PM
    #921
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Same, but I forgot the rubber pads and I used German torque values ....gudentite
  2. Mar 27, 2021 at 6:18 PM
    #922
    trd4x4boy
    trd4x4boy Well-Known Member
    Fairfax, CA
    2018 TRD Off Road Manual
    Thanks Aodrn - My OCD is going to kill me on this one though. That metal sure is bending.
    AODRN[QUOTED] likes this.
  3. Mar 27, 2021 at 7:33 PM
    #923
    jruiz555
    jruiz555 Well-Known Member
    I got the replacement tail light harness today, and this weekend the cap seen some snow. dog loved the doggie windows. I didnt see any leaks, only a spilled dog water bowl
    UH5pydOAIe-mE8JVVhd2E__8mtd1UvZoAv4yWIkC_1d3b3cb7ca81516681bacbd1d5f2e67671b06954.jpg
  4. Mar 27, 2021 at 10:00 PM
    #924
    Highline
    Highline Member
    2021 DCLB
    Bilstein 5100 up front Icon AAL out back
    Man, I can’t imagine 6 ft lbs of torque doing that. Are you sure your using an inch lbs torque wrench and not ft lbs wrench because 70 foot lbs would do that for sure but not 70 inch lbs.
  5. Mar 27, 2021 at 11:02 PM
    #925
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    So I was able to switch the pins/wires in the harness to get it to work. Takes about 5 minutes and is way faster than waiting for a new harness.
  6. Mar 27, 2021 at 11:04 PM
    #926
    chuam
    Marcus
    San Diego
    Also, no need to drill a hole to get your wiring through.
    978A9AA8-6276-4D47-B29C-05D99305CABE.jpg F87237FE-C331-4342-8AAA-53D845B49464.jpg 6AD4F703-3AFE-4EEE-BAA8-D2A38D9AC415.jpg
    Sickoreo and Brewmedic like this.
  7. Mar 28, 2021 at 5:29 AM
    #927
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    Mines doing the same and it was torqued to spec and has the rubber block underneath. I backed it off and triple checked it.
    SeaTeaSnow, cgraydog and trd4x4boy like this.
  8. Mar 28, 2021 at 6:30 AM
    #928
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    70 ft-lbs is going to do a hell of a lot more damage than that. I'm pretty sure the bolt would be long gone before you reach it, and the bolt probably would not be the first thing to go.
    Mine looks the same. I actually bought another torque wrench not totally trusting my harbor freight one.
    For some quick math, 6 ft-lbs of torque on an M10 bolt is around 915 lbs of clamping force, 9 ft-lbs of torque is about 1,375 lbs of force. I kind of suspect 6 ft-lbs is sufficient, unless you have a bunch of weight on top of the cap AND do some steep roll off-roading.
    What do other caps require to be secured? Are there any torque guidelines on the bed rails in general?
    trd4x4boy[QUOTED] likes this.
  9. Mar 28, 2021 at 6:31 AM
    #929
    trd4x4boy
    Fairfax, CA
    70 ft lbs would rip the clamp rail off the side of the bed goober.
    Kingair and Aodrn put my mind to rest for now but I’ll be watching the welds on those gussets above the pulled down metal.
  10. Mar 28, 2021 at 9:27 AM
    #930
    Highline
    Highline Member
    2021 DCLB
    Well, looks like I stand corrected.
    I was able to get four of the six torqued to 9ft lbs, the others I snugged down.
    Maybe my torque wrench is reading wrong.
  11. Mar 28, 2021 at 8:59 PM
    #931
    dzmconstr
    dzmconstr Well-Known Member
    Virginia
    I used 9ft lbs on all 6. Heard some cracks/snaps and the cap rail definitely deflects down to the bed rail a bit, but overall not that bad - not nearly what trd4x4boy has in the middle. I was really nervous about 9ft lbs and watched closely...If i did it again - probably wouldn't go to 9, probably 6 like has been mentioned.
    Dzm
  12. Mar 29, 2021 at 8:56 AM
    #932
    snelson3
    snelson3 Member
    Northern Illinois
    So here’s what has happened so far:
    - I received a new harness with three pins due to the LED tail lights.
    - When I installed it, the 3rd brake light didn’t work. I had to change the wires that I “fixed” earlier which had them backwards. It would appear that either RSI made the switch in the new harness to correct for the earlier error or LED tail lights have a different pin out with respect to polarity.
    I don’t have much confidence that I will be receiving a new harness with the wires corrected so I just used shrink tubing and soldered everything together nicely now.
    Hope that helps.
    Kingair84 and AODRN[QUOTED] like this.
  13. Mar 29, 2021 at 4:03 PM
    #933
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    https://www.rsismartcap.com/register
    "This page doesn't exist"
    Go back out, and drop down to North America; land on this page:
    https://www.na.rsismartcap.com/register
    And get a blank page (I'm using firefox)
    Go into google chrome, the page loaded!
    The fun part was red ballpoint pen was used to write the serial number. Not too visible.
    Progress, I got it together, all the clips in so making progress.
  14. Mar 30, 2021 at 10:24 AM
    #934
    Tgruetzm
    Tgruetzm Well-Known Member
    2018 DCSB OR MT
    I was thinking about bed stiffeners since most people with caps and especially caps and weight on a rack run them. I’m thinking they aren’t really needed with the rsi cap though. With a traditional cap, the bed rails keep the cap from wanting to push out. Fiberglass doesn’t have the same rigidity. With the rsi the cap would help keep the bed sides square.
    Anyone else thought about this?
    jruiz555, roundrocktom and Kingair84 like this.
  15. Mar 30, 2021 at 10:28 AM
    #935
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    I think any help to keep the bed in one piece is a great idea
    jwctaco likes this.
  16. Mar 30, 2021 at 10:30 AM
    #936
    dzmconstr
    Virginia
    An ounce/$100 of prevention vs horrible results.
    jwctaco likes this.
  17. Mar 30, 2021 at 11:53 AM
    #937
    chuam
    Marcus
    San Diego
    It may not need it but I bought the Total Chaos bed stiffeners to make sure i don't have the issue. It's cheap insurance as others have said.
  18. Mar 30, 2021 at 12:29 PM
    #938
    ret42
    VA
    I had thought about it, and came to the same conclusion - the cap should retain its shape better. The bed has more give though, so as you load up the cap with say the 700lb static weight its rated for, all of that is being transferred to the bed's frame, plus the ~180-200lbs of the cap itself. So what is the frame of the bed rated for, and where is the stress point going to be when the rigid steel cap holds its shape?
    I don't know that the bed stiffeners are really the answer to this, and obviously 900 lbs on a frequent basis isn't everyone's reality, but I like exaggerating to illustrate the point.
  19. Mar 30, 2021 at 2:30 PM
    #939
    snelson3
    snelson3 Member
    Northern Illinois
    I'm not sure if this has been posted already, but rather than sifting through 48 pages I thought it might help someone else here.
    The following can be used on the roof rails with the nuts & just the eye bolts inside underneath into the brass insert nuts:
    Eye Bolts: Amazon P/N B07G212F6H -- ~$13 for (6)
    Square Nuts: Amazon P/N B07WDS7B3L -- ~$8 for (20)
    I'm sure there's lots of other ways but I can say that these two parts work.
  20. Mar 31, 2021 at 7:59 AM
    #940
    DirtneckBill_CO
    DirtneckBill_CO Member
    William
    2021 Black Tacoma TRD Off-road Access
    Anyone know of some good straps for the EvoA Molle panels that don’t involve drilling?
    snelson3 likes this.
