RSI SmartCap Gullwing Molle Storage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crosbaugh, Nov 27, 2021.
  1. Nov 27, 2021 at 12:10 PM
    Crosbaugh
    Crosbaugh [OP] Well-Known Member
    For those of you with the RSI SmartCap EvoA, what are you storing on the molle panels? Are you running into issues with gear having to be stored upside down?
  2. Nov 27, 2021 at 5:18 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    There is 2 specific rsi threads that you’d likely have better luck with your question
  3. Nov 27, 2021 at 7:06 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    It would depend on the gear. Personally, I will not be storing anything in bags on it due to access. Recovery straps, flashlights, Etc. it will not matter and will get them up and out of the way.
  4. Nov 27, 2021 at 9:02 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Yes, but once the gullwing doors are closed (which they are most of the time) then everything is the right way...
    I store the first aid kit, paracord, batteries, ESSE 5, ESSE Junglas, mylar emergency blankets, flashlights, matches, lighter, etc...
  5. Nov 29, 2021 at 8:44 AM
    Crosbaugh
    That makes sense! Thank you both
