RSi SmartCap (Photo Heavy)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aaronparker001, Sep 3, 2020.
  1. Oct 13, 2021 at 10:51 PM
    #641
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Okay so I still don’t understand what’s going on.. I had the “RSI brake light wire that had the red and white “crossed” so I switched those and now am getting power from the factory brake light harness into the rsi rear brake light. However, the last connector that branches and runs to the bulb won’t power the bulb. Am i missing something? So frustrated by this haha
  2. Oct 13, 2021 at 10:52 PM
    #642
    TwinTaco31719
    Eric
    Glenbrook, NV
    The 3rd picture shown is the only connector that’s not drawing any power.. the 4th picture just compares the factory bulb connector and the one provided by rsi
  3. Oct 14, 2021 at 12:48 AM
    #643
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Is there only 2 wires in the rsi harness? Sure looks like it and if so I’d suspect that’s why.
    Just checked- The short length connectors that go to the taillight have 3 wires on my harness and the longer single connector to the canopy will have just 2
    TwinTaco31719[QUOTED] likes this.
  4. Oct 14, 2021 at 5:39 AM
    #644
    TwinTaco31719
    Eric
    Glenbrook, NV
    Man this thing was all jacked up! So can it be fixed? Or is this harness trash?
  5. Oct 14, 2021 at 5:45 AM
    #645
    TwinTaco31719
    Eric
    Glenbrook, NV
    Yeah my rsi harness has just two wires on all the connectors. This may sound dumb but could I take the green ground wire coming from the truck and just reroute it going to the bulb? Then just have two wires on the other two rsi?
  6. Oct 14, 2021 at 6:10 AM
    #646
    baldbeardedtaco
    FL
    Im not sure I’m following- it’s early but I’m sure it can be fixed. I think just removing the sealing plugs (for the 3rd wire) from the 2 taillight (rsi) connectors and adding a wire.
    I was given extra parts terminals/seals, I can make you the wire with terminals attached and all you’d have to do is insert if you like. Just pm me your address
  7. Oct 14, 2021 at 6:22 AM
    #647
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    RLD is nice, good quality but to me it's too upright, kinda square'ish...
  8. Oct 14, 2021 at 7:04 AM
    #648
    TwinTaco31719
    Eric
    Glenbrook, NV
    Thank you for all of your help!!
  9. Oct 20, 2021 at 4:50 PM
    #649
    MarinerSax
    MarinerSax Member
    2017 Tacoma TRD Off Road
    I joined the RSI Smart Cap crowd this weekend and just wanted to share a few pics of the install, especially how I routed the 3rd brake light harness. It was only after I had the cap on the bed did I see that you could route the harness up through the side of the bed under the plastic. I wasn't about to remove the cap again to do that, so I took a different approach and just drilled a 3/4" hole in the side of the bed (gasp.) and ran the wire through there. Zip tied the extra harness slack up in the wheel well. Found some 3/4" wire grommets on Amazon to plug the hole up and make it look nice. Good access from the driver's side bed storage box to get in there and do all this. Just wanted to share. Previous posts were super helpful to me, so thank you all!
    devale likes this.
  10. Oct 20, 2021 at 5:09 PM
    #650
    baldbeardedtaco
    FL
    So you put the plug behind the bed? I have a grommet that would likely work in that spot. I spec’Ed it out for the thickness of the cubby box and the inner diameter spec’Ed out for a tight fit/seal with I believe 3/8 corrugated sleeve. It would be a tighter seal than what looks like slits and you could pull the plug out for access… I guess unless you did that on purpose
  11. Oct 20, 2021 at 6:05 PM
    #651
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    You don't need to drill at all. See how I routed mine without needing to drill a hole:
    https://www.tacomaworld.com/threads/rsi-smart-cap.679267/page-47#post-25419804
  12. Oct 20, 2021 at 10:27 PM
    #652
    baldbeardedtaco
    FL
    I didn’t drill, I was offering up a grommet. When I had the fiberglass I wired it near the spot you posted except it’s between the bed and sheet metal (didn’t know just 2” forward was a knockout) I did end up bending the metal at that corner for a little more play and out of frustration. I may try to bend it back into place
    you can kinda see it here.
    OmahTako and chuam[QUOTED] like this.
  13. Oct 21, 2021 at 7:02 AM
    #653
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    You sir are what this site should be about!:thumbsup:
  14. Oct 21, 2021 at 7:51 AM
    #654
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
  15. Oct 21, 2021 at 7:44 PM
    #655
    baldbeardedtaco
    FL
    Nah, I def don’t deserve a prop up. I’ll help when I can/if I can dependent on mood tbh. I’ve contributed to the unwelcoming posts/snark replies etc. so I’m no solid role model. I just try to do better going forward if I slip.
    I am learning- with age, comes wisdom… and the next level of sarcasm and idgaf :rofl:
    OmahTako[QUOTED] and 10ECTACO like this.
  16. Oct 24, 2021 at 5:29 PM
    #656
    PowerFlower
    PowerFlower Well-Known Member
    Southern Oregon
    2021 OR DCLB Army Green
    Smart Cap + long bed, shuttled a lot of cannabis in the rain today, after the can-am broke down.
  17. Oct 26, 2021 at 12:29 AM
    #657
    Tucker2020!
    Tucker2020! Well-Known Member
    After 6+ months of having this cap - I just noticed the running light issue due to a missing wire on their "old" harness. Of course, after installing it when the sun was out, I just checked that the brake lights work, and of course it did because the "blue" wire was there - I didn't bother to check if the running light was functional. It wasn't until my buddy told me my running light was out that I figured out that the wiring harness supplied by RSI was missing a "green" wire to tap into the factory running light, sighs. Unless RSI has an updated wiring harness in stock, I will have to get rid of the original wiring harness, and have to fix it the old fashion way, tap the cap's 3rd brake light into the blue wire, and ground it to the frame. I have to admit, I love the cap but screwing up a 3-wire harness is disappointing for a cap that costs almost $4000.
    PowerFlower likes this.
  18. Oct 27, 2021 at 1:53 PM
    #658
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Did you order from us? If not, still happy to help. Smartcap will gladly ship you out another harness. You just need to submit a warranty claim. If you did order from us, send me a PM with your order number and I'll submit the claim for you.
  19. Oct 27, 2021 at 3:09 PM
    #659
    OmahTako
    SoCal
    It’s all under warranty so file a claim and they will take care of you. RSI has great customer service.
  20. Oct 27, 2021 at 7:44 PM
    #660
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    I went to a SnugTop dealer to price and plan. They had a SmartCap Adventure in stock and despite not planning on purchasing a bed cap for a few months I ended up scheduling an instal for Nov, 12th.
    Pricing is close to the same as a SnugTop Rebel with gullwing side windows.
    jwctaco, Luis2017 and OmahTako like this.
