RTT Mods
Discussion in 'Off-Roading & Trails' started by tacodane, Oct 31, 2013.
  1. Jan 29, 2014 at 8:21 AM
    #221
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2
  2. Jan 29, 2014 at 11:49 AM
    #222
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
  3. Jan 29, 2014 at 3:13 PM
    #223
    tacodane
    tacodane [OP] The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
  4. Feb 21, 2014 at 9:15 PM
    #224
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I've thought about led strips. But you gotta have quick disconnects on wiring to battery, are you also running a deep cycle battery or separate power
  5. Feb 21, 2014 at 9:28 PM
    #225
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    Subd cuz I'll have one by next month!
  6. Feb 21, 2014 at 10:09 PM
    #226
    Quantum731
    Quantum731 Active Member
    Brian
    Severn, MD
    2011 Tacoma Double Cab TRD
    OME 4" Lift (886 + Dakar Leaf Pack w/Overloads) ARB Front Bumper Avid Rock Sliders BajaRack ARE Shell CDN M101 Offroad Trailer Build OzTrail 375-OR Tent
    Love my setup. Have a modified CDN M101 trailer with an OzTrail 375OR tent. Added 3 zones of LED strip lights on dimmers with AC/DC power. I have gotten spoiled with them, great to have all the light you need. Working on adding a solar setup as well.
  7. Feb 21, 2014 at 10:16 PM
    #227
    Quantum731
    Brian
    Severn, MD
    Here you go. http://oztrailnorthamerica.com/OR375_OR.html I had a regular RTT previously but having a little boy to tag along, that sleeps in a pack n play still, + 2 big dogs, I had to figure out more room. Lol
    I also have the sunroom walls and floor so it is really huge, and protected from the elements... :)
  8. Feb 21, 2014 at 10:17 PM
    #228
    Quantum731
    Brian
    Severn, MD
    Here is my old setup, same trailer but on 35's.
  9. Feb 21, 2014 at 10:32 PM
    #229
    Quantum731
    Brian
    Severn, MD
    Thanks, and will do. I love sharing what I have learned over the past few years with the evolution of the trailer/tent setup. Getting ready to make some big investments on it myself. But it is good to be able to answer questions for folks as well. I didn't have many people to ask so I try to give back as much as I can. :)
  10. Feb 22, 2014 at 6:32 AM
    #230
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    You're overthinking it way too much. All I have for power supply to my tent lights and other accessories is a long wire connected to a 12volt plug. When I set up camp I pull the wire out of the tent through the hole at the hinge, open the door to the truck, plug it into an always hot 12v outlet, then close the door. When it's time to put the tent away I coil up the wire in the tent. LEDs draw hardly any amps so you shouldn't have a problem draining the battery unless you leave the lights on for a really long time without starting the truck.
    If my tent stayed on my truck 100% of the time and I wanted to hard wire it I could run wiring to the roof and use a weather pack connector like Hagen posted a link too, but I don't see a need for that. Plus I can always use the tent on another vehicle and my 12v cord will still work.
  11. Feb 22, 2014 at 8:02 AM
    #231
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    HOLY SHIT!
    that's fucking awesome! bet that takes a bit to setup, but damn that's a slick setup!
  12. Feb 22, 2014 at 9:21 AM
    #232
    Quantum731
    Brian
    Severn, MD
    I use the DC modular plugs that are pretty standard on the LED strips. And you can buy a 20 pack of those waterproof connectors from the manufacturer for around $15 if you really want to go that route. I also added a set of inline dimmers for each of the 3 LED strips. I will draw up a pic but it is:
    Battery or AC Power supply --> 3-Way Modular Splitter --> Dimmer Switch --> LED Strip. There are some great marine-grade USB and 12v connectors as well that I have and intend to mount flush next to the mattress. Blue Sea makes great stuff and is quite affordable. Used them for battery switches, distribution/fuse blocks, etc... Makes for nice clean wiring, flexibility, and quick setup when you get where you are going.
    If you are worried about power, don't be. I use an old lawnmower battery I had kicking around and with the dimmer/LED setup, draw is very very low. I have yet to drain that questionable battery even after 3-4 days... Lol
  13. Feb 22, 2014 at 9:25 AM
    #233
    Quantum731
    Brian
    Severn, MD
    Hahaha thanks. In reality, if you just do the main tent and not the sunroom, it takes about 10 minutes to setup. Very smart design. Basically identical in setup time to my old RTT setup (Camping Lab RTT). The sunroom takes another 45 minutes with a beer in hand and a kid to watch. :p
    Like I said, this weekend I will write-up my build to share because I have put so much research and thought into it, I hope others can benefit. This can be so expensive I was always paranoid about making bad choices and wasting money. Lol
  14. Mar 10, 2014 at 9:08 PM
    #234
    Toyanvil
    Toyanvil Well-Known Member
    I added LED strips into my RTT track, they fit perfect. My RTT is mounted on top of the trailer I built. I still need to build a switch/battery box, I am using a 12 volt battery from a rechargeable drill. So far it looks like it will work. Should make it a lot easier to load and unload at night.
    Had to make jumpers to go around the mounting bolts.
  15. Mar 10, 2014 at 9:10 PM
    #235
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    That's pretty smart. Clean install too...
  16. Mar 15, 2014 at 4:06 PM
    #236
    Toyanvil
    Just got the switch/battery box all done.
  17. Mar 15, 2014 at 4:20 PM
    #237
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Nice switch setup! I've been trying to figure out how to make a switch panel for the bed of the truck...
  18. Apr 27, 2014 at 1:47 PM
    #238
    MTgirl
    Weesa
    Bob's secret mod lair
    Made a little gear hanger/organizer thing today. I hate having to search around for my glasses and keys so hanging them from the ceiling should make them easy to find.
    It sags a little more than I'd care for but it should work just fine. I don't plan on having a ton of weight hanging from it so hopefully it won't get any worse
  19. Apr 27, 2014 at 1:50 PM
    #239
    BabyTaco
    Wyoming
    2011 RC Tacoma
    What did you use for the strap? Maybe you could used velcro to hold it up better?
    My tent has 2 large pockets and 2 smaller pockets. Why not use them?
  20. Apr 27, 2014 at 1:53 PM
    #240
    MTgirl
    Weesa
    its nylon webbing with velcro straps around the tent pole.
    my tent has pockets too but i'm paranoid about crushing my glasses in the middle of the night so i like to have them up and out of the way
