RTT ON CAB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beccajen, Jun 21, 2022.
  1. Jun 21, 2022 at 12:14 PM
    beccajen
    beccajen [OP] New Member
    Rebecca
    2022 Tacoma 4X4 Double Cab
    I know this has been asked a few times but looking for a definitive answer before purchases.
    I’m looking at mounting the Thule Tepui Kukeman 3 RTT on top my 2022 Tacoma Double Cab with the Greenlane Off-road roof rack.
    I want to mount to the roof rather than the bed to allow bed space for dirt bikes, bikes, paddleboards etc.
    I know it is often recommended to mount to the bed but I really want to mount it to the cab. I’m not worried about fuel efficiency.
    Is there any other reason I can’t do this?
    Any help appreciated!
  2. Jun 21, 2022 at 12:24 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    I think noise, fuel economy and just general unsteady ride will deter you
    Key-Rei and GarlicFarts like this.
  3. Jun 21, 2022 at 12:26 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    With the exception of dirt bikes you can put the rest on the roof with the tent over the bed. That's how I had my 2nd gen setup for a while, with the tent on a bed rack that left it just slightly below the cab and then kayaks or bikes on the roof rack when I wanted them.
  4. Jun 21, 2022 at 12:35 PM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    He's using dirt bikes, not bicycles. Otherwise that would work
  5. Jun 21, 2022 at 12:37 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    That's why my reply to her said "with the exception of dirt bikes". The solution fits two of the three desired uses mentioned for the bed.
    Wixo likes this.
  6. Jun 21, 2022 at 12:47 PM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
  7. Jun 21, 2022 at 12:49 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I guess reading comprehension is difficult for you. Oh well.
    Wixo likes this.
  8. Jun 21, 2022 at 12:56 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    The "R" stands for roof.
    No reason why you can't do this.
    I don't really understand tents on the bed for any reason other than fuel efficiency. You lose most of your bed if you actually use it for more than just a bit of gear.
  9. Jun 21, 2022 at 12:58 PM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
  10. Jun 22, 2022 at 4:24 PM
    Taconium
    Taconium Member
    2022 Magnetic Tacoma TRD Off-Road 4x4
    The OEM Tacoma roof rack load capacity is about 100 lbs spread evenly. I got Victory 4X4 roof rack, https://www.victory4x4.com/product/VT23RK.html, and they say it can handle more in static weight. However given the weight of the Tepui, which is about 120 lbs, and then additional weight of a human, the stack weight will definitely go higher up and will affect the mounts in the roof. With the RTT on the roof, it can be a disaster: https://www.youtube.com/watch?v=eMx232haRyo. Not a Toyota but you get the gist. Even if you are not buying a roof rack from
    Rhino, you can always check the roof's dynamic load here: https://www.rhinorack.com/en-us/load-rating-calculator. Truthfully, I would get a trailer or a hitch mount for the dirt-bikes if I had them.
    I am also considering the Tepui and for the bed rack I installed the Pro from KBVoodoo. they are solid. Can take 300 lbs dynamic and 800 static.
  11. Jun 22, 2022 at 4:41 PM
    Taconium
    Taconium Member
  12. Jun 22, 2022 at 4:52 PM
    Taconium
    Taconium Member
