RTT on stock suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ethan_5257, Jan 11, 2025.
  1. Jan 11, 2025 at 8:55 PM
    Ethan_5257
    Ethan_5257 [OP] Member
    Ethan
    2023 Tacoma sr5
    Hello, I’m looking to buy a bed rack and rtt, around 250lbs weight. I’m still on stock suspension. But have no plans on doing any serious off-roading just some basic camping. And was wondering if the weight of the tent and rack, plus me 220lbs and some basic camping gear would be too much in the back for my suspension. 2023 double cab SR5 4x4
  2. Jan 11, 2025 at 10:09 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Your bed load limit is at least 1000 lbs, so just the weight you mentioned should be fine keeping it stock- try it out first.
    I eventually added a Deaver add a leaf and longer shocks (5100’s) as I added a lot of stuff to it.
  3. Jan 11, 2025 at 10:39 PM
    Bishop84
    Bishop84 Well-Known Member
    The rear leaf springs are soft and even standard toppers wear out the springs at an accelerated rate.
    You can run it, but expect to be nose high when you're set to go camping full load.
    You can run an add-a-leaf as a band aid and get heavier leaf springs later. But you'll wanna do something for a more enjoyable experience.
    Road_Warrior and Chew like this.
  4. Jan 11, 2025 at 11:00 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Throw 250# of dead weight (most likely more to account for your other gear) and see how you like it. With 330# of fiberglass topper and Decked system, I was bottoming out on the roads often.
  5. Jan 12, 2025 at 5:19 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The Taco will squat in the rear, once fully loaded. You should seriously plan for better suspension.
    Chew likes this.
  6. Jan 12, 2025 at 12:53 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Run it. You will know when you need to beef the rear.
