RTT placement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jenningsintexas, Mar 19, 2025.
  1. Mar 19, 2025 at 5:38 PM
    Jenningsintexas
    Jenningsintexas [OP] New Member
    Josh
    2022 Tacoma TRD
    Newbie looking into a RTT.. My leer cap is fiberglass and is not setup to hold the weight of an rtt.
    Question is, has anyone put these tents on the cab roof of their Tacoma?
  2. Mar 19, 2025 at 6:24 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    That's gonna require some real modification to support that weight.
    the good news is your MPG should be around 5-7 mpg so you might want to add a second fuel tank but that's also gonna add a bunch of weight so you'll probably want to upgrade your suspension to take all that added weight.
  3. Mar 19, 2025 at 6:43 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Best option would be to sell the cap and get a smart cap they can hold the weight . Or you can do a bed rack with a tonneau cover . Putting a rtt on the roof is not recommended .
    Jenningsintexas[OP] likes this.
  4. Mar 19, 2025 at 7:51 PM
    EZRed
    EZRed Well-Known Member
    E
    Washington
    2023 TRD Off Road, MT
    I have mine mounted to a mid-height bed rack, but a quick search for any roof rack will tell you the racks static + dynamic load ratings.
    For example, Prinsu states theirs has a static load rating of over 1000lbs and dynamic of over 600lbs. That means it will hold 1000lbs safely standing still and 600 while driving. My Roofnest RTT weighs about 130lbs so would be no issue.
    It’s more difficult to find actual Toyota verbiage on the ‘cabs’ rating but I assume (dangerous) based on prinsu’s ratings it is not a constraint, the constraint is the security of the roof rack & how it distributes weight.
    it’ll make the truck a helluva lot taller and add the weight of the rack + the tent.
    These numbers are examples of just 1 product but any reputable roof rack or even crossbars like Yakima will provide a static & dynamic load rating. Before I got my truck we had the RTT mounted on my wife’s Subaru forester with Yakima towers + cross bars and it was just fine.
  5. Mar 20, 2025 at 1:29 PM
    desertdweller
    desertdweller Well-Known Member
    jp
    Phoenix, AZ
    2019 TRD OffRoad
    Imagine the absurdity of putting a Roof Top Tent on your Roof Top.
  6. Mar 20, 2025 at 1:36 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I have seen it done but it would not be my first choice. I had boxes on my prinsu originally and you noticed the hell out of the weight up there. I personally wouldn't want a bed rack that put the tent over can height. I put mine on 6" bed bars and wouldn't want it any higher from a driving perspective. Especially if you ever deal with off camber situations.
  7. Mar 20, 2025 at 1:54 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Yeah, what am I missing here?
    BabyBilly likes this.
  8. Mar 20, 2025 at 2:00 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
  9. Mar 20, 2025 at 4:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    My RTT weighs 125 lbs without my fat butt in it but goes up significantly when I’m in there plus add the wife and now you’re talking over 500 lbs!
  10. Mar 20, 2025 at 5:39 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Stay in a hotel ..cheaper and more cost effective
  11. Mar 21, 2025 at 1:00 PM
    MrPP
    MrPP Member
    If your leer topper has a roof rack, it shouldn't have any issue with a rooftop tent.
    Is there a rectangle that's a bit thicker on the ceiling of your leer?
  12. Mar 22, 2025 at 8:30 AM
    Kcruisin
    Kcruisin Well-Known Member
    North Alabama
    '21 TRD OffRoad
    Bumpers and winch
    I believe my roof rack is rated for 300lbs, most others I saw was in the 250 range.
    You should ask Leer about some stiffeners.
  13. Mar 22, 2025 at 8:18 PM
    Jenningsintexas
    Josh
    2022 Tacoma TRD
    Thank you for all the responses / guidance. The link is helpful to look back on as well.
    I would reply to the comments but I don’t know how to individually do that yet.
    I have asked Leer about it’s rating and they mentioned that they would not recommend putting one on top + our body weight. (But I have not thought about stiffeners. Thanks for the tip.
  14. Mar 23, 2025 at 5:43 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP- if the Leer didn’t have stiffeners installed during the fiberglass layup(original build at Leer factory), they cannot be added after sadly. They are bonded in between fiberglass layers to provide strength (usually a 6-8 ply addition to roof “load” area)
  15. Apr 4, 2025 at 8:51 PM
    Captqc
    Tigard, OR
    Ain’t no hotel within 50 miles of where I was camping!
