RTV sealant application on timing chain cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 15, 2021.
  1. Dec 15, 2021 at 9:13 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    When applying RTV sealant on the mating surface of the timing chain cover (1GR-FE), is it best to apply the bead on the side of the cover itself, on the block, or both? I am using gray around the water pump inlefts and Permatex The Right Stuff black everywhere else. The manual says use gray everywhere but I've been advised here to use black due to its superior oil resistance.
  2. Dec 16, 2021 at 1:16 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    On the cover, definitely not both that will be way too much RTV.
    wilcam47, foampile[OP] and burrito782 like this.
  3. Dec 16, 2021 at 1:50 AM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    ^This (which is what the FSM states).
    Not sure what manual you're referring to, but the FSM specifically says to use two different sealants for the oil and coolant parts.
  4. Dec 16, 2021 at 2:56 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What these guys said. Applying RTV to large removable items makes more sense than applying it to the base surfaces simply due to the fact that there is less room for sloppy installation and getting it everywhere. So yes, put it on the cover only.
  5. Dec 16, 2021 at 7:02 AM
    foampile
    Mid-Atlantic
    Haynes
  6. Dec 16, 2021 at 7:02 AM
    foampile
    Mid-Atlantic
    Makes sense -- it is much easier to apply that on the block
  7. Dec 16, 2021 at 7:08 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Here's the FSM instructions
  8. Dec 16, 2021 at 7:23 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Right stuff is awesome. Ive used it on axle cover. No leaks
