rubbed the wrong way lol
Discussion in 'Technical Chat' started by trd4us, May 15, 2008.
  1. May 15, 2008 at 7:10 PM
    trd4us
    trd4us [OP] Active Member
    va
    08 trd and 2009 reg cab
    08 trd, daystar leveling kit, k&n fipk, 285/75/16 pro comp x terrains, spidertrax wheel spacers, flowmaster 40 series exhuast.the 2009 is stock only 130 miles
    going to install the daystar 2.5 front 1.25 rear soon if the 285/75/16s rub the uca where do u find a aftermarket about how much$$$ and will it fix the rubbing issue. any info would be nice.
  2. May 15, 2008 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Total Chaos is the UCA's I run.
    http://www.chaosfab.com/96504.html
    Of all the UCA's I have looked into, these are the best. They also correct your caster after a lift. They run about $620.00 for the pair, so they are not cheap. :)
  3. May 15, 2008 at 7:26 PM
    trd4us
    va
    what do they do to fix the issue i am new to the tacoma world.
  4. May 15, 2008 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They have more caster angle built into them. They also allow a little more travel in your suspension. And they are MUCH stronger than the OEM ball joint that they replace. :)
  5. May 15, 2008 at 7:48 PM
    trd4us
    va
    cool just looked at them they r nice. i guess i will find out if i need them soon. all my friend say the tires will clear with no worries but i am stresed. new taco and the frist time ever lifted anything. i have called every 4x4 place and every one say something differnt. i got 800$ worth of tires i dont want to have to send back and run the 265/75/16 i dont think the rest of the work would b worth it lol
  6. May 15, 2008 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You ar going to rub a little bit. Dont worry about it. The places you are going to rub ar mainly plastic ( with the exception of the UCA ). I have some rubbing, but Im just waiting for the tires to rub thru it. :D Oh, what wheels are your getting for the tires?
  7. May 15, 2008 at 8:00 PM
    trd4us
    va
    stock 4 now if it will work, 4 wheel parts told me that it wont work with aftermarket wheel. i dont know like i said i have been rubbed the wrong way. would like to find a good 16x8 but not sure. all my money is almost gone with the tires, daystar kit, and the k&n fipk lol
  8. May 15, 2008 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok, now your not gonna like me, 285's on a stock wheel WILL rub the UCA. Im not sure you will be able to mount them. You will need new UCA's or wheels with a different back space. Wheel spacers may work also, but I dont know much about them, but they would be a much cheaper alternative until you get the $$$$ for UCA's or new wheels.
