Rubber bulb housing from theretrofitsource.com
Discussion in 'Lighting' started by YFZ450MOE, Dec 20, 2012.
  1. Dec 20, 2012 at 1:26 AM
    YFZ450MOE
    YFZ450MOE [OP] When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I just did a d2s retro on y taco and was wondering what size rubber housing I need for my lights. I am away from truck or I would measure myself but also want help from those who have done this. I tried cutting my stock ones to fit around the connection but that didn't work to well and the retrofit source has some that are already made just need a diameter.
    http://www.theretrofitsource.com/product_info.php?cPath=31&products_id=4649
    Here is the link for what I am talking about.
    Thanks in advance TWs!
    Moe
  2. Dec 20, 2012 at 1:32 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I think it all depends on what you cut away on your reflector housing. I'm in the same boat, probably be easiest to just wait and measure it when you can.
  3. Dec 21, 2012 at 7:08 PM
    YFZ450MOE
    Moe
    Does anyone have some extra lights sitting around that they could measure real quick??
  4. Dec 24, 2012 at 10:44 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Newington, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I think I have some extra caps if you want them
  5. Dec 25, 2012 at 1:33 AM
    YFZ450MOE
    Moe
    The stock ones?
    I have tried cutting stock ones to fit but they won't work.
  6. Dec 25, 2012 at 9:00 AM
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    It's a pain in the ass because you have to trim a little bit at a time and test fit after each trim
