Rubber flap/seal between the bed and the cab?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Knucklegrumble, Oct 14, 2016.
  1. Oct 14, 2016 at 6:58 PM
    Knucklegrumble
    Knucklegrumble [OP] Well-Known Member
    Hello Tacomers... I've been going kinda nuts cause I am trying to find online something similar to that plastic skirt that runs along the edge of the 2016 bed in between the cab... I think it's there for better aerodynamics but regardless... what I am trying to accomplish is to run it around the camper shell so that it'd create a little less air dispersion when I open the rear window in the truck and the topper... hopefully also reducing the amount of rain that gets on the windows...
    I don't know if I made any sense... Also any other suggestions/experiences with "connecting" still kind of loosely the cab and the topper is appreciated... What I would like to achieve is the best type of connection without using an inflatable boot... I don't want to scratch the paint of the cab... Ideally that flap i'm looking for would be stuck to the topper extending towards the cab and maybe touching it but not "glued" to it.
    Any thoughts?
    I married my tacoma likes this.
  2. Dec 5, 2016 at 1:27 PM
    Chaulser
    Chaulser Member
    Butch
    2017 Silver Tacoma, Dbl-Cab, TRD Off-road
    I've got a new dblcab offroad Taco inbound this week. A topper is in my plan as well as is sealing the topper to/against the cab. I'll either use a compression boot (with Trimbrite Bodyguard protection film over the painted surface) or remove both windows and use an accordion boot (but both window openings must be exactly the same size). Like to go with the accordion boot but we'll see once the truck is on station and I can get true measurements of the window rough openings.
  3. Dec 5, 2016 at 1:47 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Interested in doing something similar, never seen it done before.
  4. Dec 5, 2016 at 2:11 PM
    Lunabird
    Lunabird Well-Known Member
  5. Dec 5, 2016 at 2:17 PM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    They used to have boot that caps had if you wanted to take the window right out. They also had a clear pillowlike item so you could leave the window open all the time.
  6. Dec 5, 2016 at 2:19 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
  7. Dec 5, 2016 at 2:47 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Those look like a good product. I always bought caps with front boots, never had a problem with them rubbing paint off. One can put 3M clearbra on ahead of time if it's a worry. I did have some troubles fitting the boots underneath the 3rd brake light to get a good seal. A little tugging, a little ingenuity you get a good seal.
  8. Dec 5, 2016 at 3:00 PM
    Lunabird
    I was thinking you could DIY it. Maybe get some double sided industrial strength 3M tape and a garage door rubber seal. Make a wind spoiler on the cab of the truck to push wind up and off the canopy. thoughts?
  9. Dec 5, 2016 at 4:38 PM
    Lunabird
