Rubber floor mats cause moisture/water?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Sep 27, 2018.
  1. Sep 27, 2018 at 1:40 PM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Having rubber floor mats, do they cause moisture/wetness on the carpet? In my area, we have heavy rains and super high humidity also. I do not have any water coming from outside into my truck. When I have the mats removed, there is never any moisture of the floor under the mats
  2. Sep 28, 2018 at 12:53 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    They do seem to keep the carpet from drying out once it gets soaked.
    Because I am forever in the mud water and snow I just removed my mats and carpet .
    It used to be the carpet was either soaked or frozen
  3. Sep 28, 2018 at 2:36 AM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    I’m having the same issue. I thought I had a leak in the cowl or ac condenser leak or weatherstripping was bad but I think once the matting and carpet is wet it takes forever to dry especially in the tropics. I’m experimenting with pulling my passenger side up and placing 2 of those hanging disposable moisture absorbers and 1 cup style one. I’ll let you know how it goes.
  4. Sep 28, 2018 at 5:20 AM
    Indy
    Indy Master of all I survey.
    You're planning on regularly replacing them?
  5. Sep 28, 2018 at 8:55 AM
    vettehigh
    Jon
    Upstate, NY
    Only happens to my front drivers mat. Last night I took the rubber mat out and it poured out last night. I go to the truck this morning and the carpet is dry. Only gets moist when I leave the rubber mat in
