Rubber roof strap anchors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davistld01, Oct 15, 2022.
  1. Oct 15, 2022 at 12:07 PM
    davistld01
    davistld01 [OP] Well-Known Member
    Terry
    2019 White Tacoma SR5
    Any ideas for keeping the rubber roof strips that cover the roof-rack mounting platforms from blowing off in the drive-through car wash…better than double-sided tape?
    Super annoying!
    I tried tape, and it’s completely worthless when it gets wet & soapy.
  2. Oct 15, 2022 at 2:48 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what double-sided tape are you using?
    Key-Rei likes this.
  3. Oct 15, 2022 at 3:04 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    3M trim adhesive 3/4" wide but make sure you thoroughly clean the mating surfaces then wipe everything down again with isopropyl alcohol.
    hiPSI, na8rboy and soundman98 like this.
  4. Oct 15, 2022 at 3:11 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    I took mine back to the dealership a couple of times, they said "they all do it, nothing we can do". I contacted Toyota USA, they asked that I take the truck back to the dealership and they would fix the issue....they did.
  5. Oct 15, 2022 at 3:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    https://www.amazon.com/3M-08609-Window-Weld-Urethane-Cartridge/dp/B000FW61EW/
    May also be available at your local auto parts store, like Napa: https://www.napaonline.com/en/p/MMM08609
  6. Oct 15, 2022 at 4:03 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    They put a dab of panel bonding adhesive under them to get you to go away. The dealer was more or less right when they said "they all do it, nothing we can do". Its a poor design from toyota and the only fix is to glue them down.
    3JOH22A and bulalo like this.
  7. Oct 15, 2022 at 6:56 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    PSA for anyone going the windshield urethane route... that stuff is worse than anti-seize!!! gets everywhere, and I mean EVERYWHERE! even when you are taking your time, and trying to do it cleanly. dont wear anything you value, and dont have the doors or windows on the truck open, when you do this.
    clean up only smears it. you need to use a good solvent to "help" get most of it out, off. if it gets on anything made from cloth... forgetaboutit!
    YOU HAVE BEEN WARNED! Ski
    whatstcp and 3JOH22A[QUOTED] like this.
  8. Oct 15, 2022 at 11:07 PM
    soundman98
    NW Indiana
    quoting for being worth repeating.
    with even terrible prep-- a paper towel and a bottle of windex, genuine 3m tape holds just as good as any panel adhesive.
    the hardest part is getting genuine stuff-- most listings on Amazon and ebay seem to be fakes. the few that i've tried all work better as door stops than they do as adhesives.
    on my car, the spoiler is held on entirely by 3m tape, since 2016. the louver attachment points are also 3m tape, for the past 2 years.
    whatstcp and Key-Rei[QUOTED] like this.
  9. Oct 16, 2022 at 1:29 PM
    davistld01
    Terry
    I tried Super Glue, and it…just like the double sided tape, let loose as soon as I hit the air-dryer portion of the car wash!! :mad:
    My plan is to shoot a couple of rivets in it soon. I bet that SOB doesn’t fly off then!
    Toyota dropped the ball on this deal, for real. Of course, they probably just want to sell you an overpriced roof rack.
  10. Oct 16, 2022 at 5:23 PM
    soundman98
    NW Indiana
    nah, superglue is too brittle, especially to a painted metal surface.
    that really only works with a crazy amount of prep, and it's mostly plastic/rubber compounds that it bonds well with.
    whatstcp and Key-Rei like this.
  11. Oct 17, 2022 at 1:09 PM
    AZ Pete
    Arizona
    didn't know you were there. They fixed it, as was their responsibility..
  12. Oct 17, 2022 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude mine haz zero problems in a car wash along with tens of thousands others. Sorry man but most hold just fine.
