Rubber shift boot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NUMMI TACOMA, Feb 16, 2018.
  1. Feb 16, 2018 at 2:25 AM
    NUMMI TACOMA
    NUMMI TACOMA [OP] Well-Known Member
    San Jose, CA
    2010 SR5 2.7L 5 Speed 4X4
    Hey all, I’m looking to install a hurst / core short shifter in the semi-near future, but I’m not so sure I want to re-install the leatherette shift boot again. I kind of like the old school look of the rubber shift boots and would like to find something similar to replace the stock one. I know there’s a small rubber boot underneath the stock leatherette one, but I want something that will mount up flush with the existing console. Anyone have any ideas?
  2. Feb 16, 2018 at 2:35 AM
    NUMMI TACOMA
    San Jose, CA
    Actually, core has some hurst boots on their site that I somehow missed my first few times on there. I reached out to them to try and figure out which (if any) will fit in the Tacoma.
  3. Feb 16, 2018 at 7:40 AM
    NUMMI TACOMA
    San Jose, CA
    Well, it’s not the response I was hoping for:
    “I only recommend the stock boots. There is no aftermarket boot that is going to work out in that application.”
    Anyone else have ideas or recommendations?
    scottalot[QUOTED] likes this.
  4. Feb 16, 2018 at 9:40 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I think the issue is that the stock one is attached to the center console and the Hurst boots attach to the floor via a trim ring. I'd look at the size of the base of the Hurst boot and see if it is the same basic size as the hole in the center console and then figure out a way of attachment.
    scottalot likes this.
  5. Feb 16, 2018 at 11:17 AM
    NUMMI TACOMA
    San Jose, CA
    That’s what I’m leaning towards. Any ideas on attachment/securement?
  6. Feb 16, 2018 at 2:12 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    From memory, the stock boot is attached with a wire that snaps to the underside of the console. You'd probably have to replicate a similar set up.
