Rubber Wiper Blade Insert Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chandler1215, Mar 2, 2020.
  1. Jun 10, 2020 at 12:13 PM
    #41
    17TRD
    17TRD Well-Known Member
    2017 TRD OR 4X4 DCSB
    OEM Toyota wiper refill part numbers :D
    Part Number Part Name Price Quantity Total
    85214-0E140 Windshield Wiper Blade Refill $7.37
    85214-04030 Windshield Wiper Blade Refill $7.37
    musicisevil, iblis01 and Rainoffire like this.
  2. Jun 10, 2020 at 2:52 PM
    #42
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
  3. Jun 10, 2020 at 3:21 PM
    #43
    DarthR2D2
    DarthR2D2 Well-Known Member
    17DCLBSPORT4X4
    Same here. I just wipe them down with soap and water every now and then.
  4. Jun 11, 2020 at 1:17 AM
    #44
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I use a small amount of laquire thinner and they will soften right back up. Two and half years on my factory blades and they perforce like new. Keep in mind I garage my truck everyday and it rarely sees rain.
  5. Jun 11, 2020 at 6:30 AM
    #45
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Bosch Icon's beam blade is the way to go...
  6. Nov 4, 2020 at 5:07 AM
    #46
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Depends on the wipers you buy. Those cheap metal and rubber ones hardly last more than 6 months. But quality ones can last over a year with heavy use. The OEM wipers are good, but definitely not the best I've ever had.
  7. Nov 4, 2020 at 5:13 AM
    #47
    RedWings44
    Michigan
    I've never once ripped a front wiper blade, living in Michigan and also experiencing ice and snow. Just be sure you're not using them over ice when it can be avoided. Apparently a lot of people just spray their windshield with the wiper fluid and try to get the wipers to do the rest. I've never understood that. That's what the defroster and an ice scraper is for.
    CusterFan likes this.
  8. Dec 31, 2020 at 1:41 PM
    #48
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Glad I saw your post. :) I had a set installed at O'Rielly's on my '19 Tacoma this morning. Been over on Amazon reading reviews and folks don't speak too highly of them. I could of went with Bosch Icons for more money but I saw the $10.00 off on the Trico Force. People complaining about chatter but I use Wolfgang Rinseless Wash UBER as a detail spray. I clean my windshield with it after every wash so it should be plenty slick and I'm hoping I won't have a issue with chatter.
  9. Dec 31, 2020 at 2:00 PM
    #49
    CusterFan
    And a spray bottle of Prestone Windshield De-icer. Love the stuff.
  10. Jan 1, 2021 at 6:11 AM
    #50
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Around Halloween which is when the weather starts to turn, I do several things. I spray down my undercarriage with anti rust spray and I replace my wipers with OEM inserts.
  11. Jan 1, 2021 at 7:40 AM
    #51
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I probably sold over a million complete wiper blades and rubber inserts over my 16 years owning/operating a chain of auto parts stores. Keep in mind that the wiper arms and blades (frames) play as important role in keeping your windshield clean, dry and streak-free as the rubber inserts. Personally, I always replace the blades/frames as opposed to just the rubber inserts as they don't cost that much more and very often it's your frames that have lost tension and not applying even pressure against the windshield causing problems.
  12. Nov 8, 2022 at 5:55 AM
    #52
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Hi all! Sorry to revive a 2 year old thread. Has anyone replaced their blade inserts recently? Mine are in need of replacement...but my dealership said they can order them for 30 bucks...EACH. They told me they could get the whole assembly for 20. I'm also having a hard time finding them online. Anyone have a source for these inserts? Or a good recommendation for the cut-to-fit style?
    Thanks in advance!
  13. Nov 8, 2022 at 6:04 AM
    #53
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I bought mine from McGeorge Toyota. I believe only the right side says that you need to order 10 of them, but I was able to order just one set without issue.
  14. Nov 8, 2022 at 7:33 AM
    #54
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  15. Nov 8, 2022 at 10:22 AM
    #55
    dr4g1116
    I checked and they're showing unavailable on Sparks.
    Finally just found them at the next closest dealership for $16 out the door. Clearwater Toyota must be out of their minds, or got the wrong part number.
  16. Nov 8, 2022 at 1:44 PM
    #56
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    Last time I bought inserts from a Toyota dealer they said that they were no longer stocking the inserts, but had a few left. The next change, I just replaced the entire wiper.
