rubberized flooring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xer0 SiN, Jan 29, 2013.
  1. Mar 5, 2013 at 6:19 PM
    #41
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    The rubber wont breathe though like the carpet so if you get moisture under it like in that stuck, youll never get rid of the moisture unless you pull the rubber flooring, then you will need new floor pans. Brutal.
    The lesson is never get stuck.
  2. Mar 5, 2013 at 7:12 PM
    #42
    AstroReutz
    AstroReutz Member
    Damn. That, is having a bad day.
  3. Mar 5, 2013 at 7:22 PM
    #43
    BradyT88
    BradyT88 Well-Known Member
    Those pics aren't of the same person. They were just the first pics that came up on google that showed what I meant. I have seen several pics of guys that have flooded out their rigs on here I just couldn't find them again... so I turned to google. haha
  4. Mar 5, 2013 at 7:41 PM
    #44
    Brandon###
    Brandon### Well-Known Member
    If you sink your tacoma and flood the interior with water, it doesn't matter what kind of flooring you have because it all needs to be pulled out immediately to prevent mold/mildew.
    "All weather flooring" was designed to be easy to clean if it got dirty. It is not tsunami proof.
    I don't care how much you try and seal holes, or the floor, it will never be completely water tight, and if you are an idiot you can still get water inside the cab.
    The other misconception is the difference in noise level. There is none.
  5. Mar 5, 2013 at 7:43 PM
    #45
    AstroReutz
    AstroReutz Member
    No shame in the Google Machine. The point was made.
  6. Mar 6, 2013 at 6:45 PM
    #46
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Line X the floor and run cable looming as best you can. Done, never have to take anything out again!
  7. Mar 6, 2013 at 6:50 PM
    #47
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Get a 40" lift and you won't worry about getting water inside.
  8. Mar 7, 2013 at 6:01 PM
    #48
    Brandon###
    Who would do this to a newer truck? That is ridiculous.
    I would pay money to see someone go through 4 feet of water thinking a line-x floor and cable looming will solve all of their problems :popcorn:
  9. Mar 7, 2013 at 7:19 PM
    #49
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Yup and getting stuck in the water like the picture is just as ridiculous (for a new truck).
