Rubbing after 5100, ome Springs, leafs and 17x9” fuel shock w 285 bfg.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Saltysack, Apr 7, 2021.
  1. Apr 7, 2021 at 7:40 AM
    Saltysack
    Saltysack [OP] Well-Known Member
    Richard
    Loads of yotes
    Currently have 888 springs on 2020 taco doing the lift vs the 5100...set at zero. I’m getting rubbing on turn with compression. If I raise the the 5100 up will achieve more lift than just 888 springs alone alone?
  2. Apr 7, 2021 at 7:50 AM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    You can't lift your way out of rubbing on compression. The tire is just returning to where it started before the lift. You need to either move the tire forward (increasing caster using lca can bolts and alignment) or trim the offending material.
    I'm guessing those wheels have a negative offset? That helps your 285 clear the UCA but causes a wider scrub (path of the tire while turning) radius.
    Someone will come along and correct my terminology but basically you need some combo of alignment or trim/reshape to get rid of the rub. Increase lift can make it seem gone until you stuff the tire.
    whatstcp likes this.
  3. Apr 7, 2021 at 7:56 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    ^ sounds about right. I can fit a 285 too, but trimming is irreversible so I'm sticking with a 265 to prevent that rub.
    71tattooguy and whatstcp like this.
  4. Apr 7, 2021 at 7:58 AM
    Saltysack
    Richard
    Loads of yotes
    I also did uca but assume doesn’t help rear front tire clearance
  5. Apr 7, 2021 at 7:59 AM
    Saltysack
    Richard
    Loads of yotes
  6. Apr 7, 2021 at 8:03 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    ^correct.
    Max your caster with LCA. Get a CMC. Heat and reshape fender liners. Cut what can't be massaged.
    Also correct. Your aftermarket UCA most likely has caster built in but will move the tire backwards.
  7. Apr 7, 2021 at 8:06 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    VaToy likes this.
  8. Apr 7, 2021 at 8:41 AM
    Fish.Taco.Ma
    Fish.Taco.Ma IG: @fish.taco.ma
    Dean
    2017 Silver Sky Tacoma TRD Offroad
    How many miles do you have on the tires, if you are just barely rubbing they might wear down enough in a few thousand miles that you will no longer be rubbing. Really a CMC is no big deal. Plenty of places out there at are reasonably priced and come out looking super clean!
  9. Apr 7, 2021 at 12:22 PM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    What wheels are you running?
  10. Jun 29, 2021 at 5:21 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Im putting ko2 285/70/17 on the same setup 5100/888 set at 0. My wheels are ray10 -10 offsett. Will i rub?
    I tried my buddys same tires on +12 wheels with no rubbing whatsoever
  11. Jun 29, 2021 at 7:10 PM
    angerbot
    angerbot Well-Known Member
    Almost definitely.
    Thunder Fist likes this.
  12. Jun 29, 2021 at 7:17 PM
    50ate
    50ate Well-Known Member
    Washington
    2019 OR DCSB 6spd
    Especially in a bout 2k miles when the 888 start to sag out like a pair of 50 year old tits.
    this shit never ends, there all gonna rub. If you can’t bolt them up stock and not rub there gonna rub. Period.
  13. Jun 29, 2021 at 7:34 PM
    cruxx
    Huy
    2017 TRD Sport
    Whats 22mm. Had them on with no rub whatsoever. Well gonna do it anyways and fix what needs fixing afterwards
    manncyclesupply likes this.
  14. Jun 29, 2021 at 7:35 PM
    cruxx
    Huy
    2017 TRD Sport
    Well past 2k on these 888s
  15. Jun 29, 2021 at 7:38 PM
    ascendr
    ascendr Active Member
    285/70/17 KO2's on 17x9 -12 offset 4.5 BS w/ 2.75" lift and UCAs. (Driver side)
  16. Jun 29, 2021 at 7:40 PM
    angerbot
    Now enter a driveway with the wheel turned.
  17. Jun 29, 2021 at 7:41 PM
    50ate
    Washington
    2019 OR DCSB 6spd
    He can’t he’d tear the fender out… cause they don’t fit
  18. Jun 29, 2021 at 7:43 PM
    cruxx
    Huy
    2017 TRD Sport
    Yall are kill joys lol. Anything i can do with alignment to help the situation?
  19. Jun 29, 2021 at 7:45 PM
    angerbot
    Mate just pony up for a CMC and some plastic trimming. It's really really not the end of the world.
    manncyclesupply and cruxx like this.
  20. Jun 29, 2021 at 7:47 PM
    cruxx
    Huy
    2017 TRD Sport
    Or put the 5100 up a notch or just get more positive wheels i guess or the worse option and go back to 265s
