rubbing after toytec c/o and TC UCA - not a duplicate thread
Discussion in 'Wheels & Tires' started by ComaTosin, Mar 11, 2009.
  1. Mar 11, 2009 at 2:48 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    i did not want to hijack the other thread but realize this is similar.
    i have American racing polished aluminum wheels 16x8 with 4.5 backspace (i think, bought 3 years ago) with bfg 285/75/16 AT on them. I used to have daystar 2.5" spacers up front and had no rubbing issues after trimming. I upgraded the suspension to Toytec C/O and TC UCA and now have rubbing issues due to the UCA pulling the wheels back under the truck a bit more.
    I know the lift height is exactly the same. my question is -
    Will a wheel with more backspacing cure this issue? I can not trim any more. I want to avoid wheel spacers at all cost. I have had a very bad experience with loosening lug nuts (on the highway!) and will not chance that happening again.
    wheel suggestions with proper backspacing? here is what i was looking at:
    $105 from summit racing American Racing AR-23
    $117 from discount tire.
    http://www.discounttire.com/dtcs/fi...72&c=1&rcz=30309&pc=72225&wd=16&rw=&rc=GAAINT
    Thanks
  2. Mar 11, 2009 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Cant see the pics, but, have you considered raiseing the CO's another 1/2"?
  3. Mar 11, 2009 at 10:45 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    use loctite or however its spelt on the studs when running wheel spacers.
  4. Mar 11, 2009 at 10:57 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Wouldn't you want wheels with less backspacing to make them stick out a little further?
  5. Mar 11, 2009 at 11:12 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    yes....the stockers are 5.5" BS and most go w/ a 4.5" BS to clear uca's
  6. Mar 11, 2009 at 11:15 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    x3 on the locktite and x2 on cranking the coilovers up...
  7. Mar 11, 2009 at 12:00 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    tried earlier. WTF WTF WTF?
    those things are really tough to move. am i just being a pus.... here?
  8. Mar 11, 2009 at 12:02 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    i have 4.5 but not clearing the frame. have to go up a bit i suppose. if i could only make the damned toytecs move.....
  9. Mar 11, 2009 at 12:32 PM
    LonghornTaco
    Minnesota
    Whenever I've needed to adjust my coilovers, I've had to remove them. I couldn't make them budge. It could be a case of leverage too... Those spanner wrenches really aren't that long...
  10. Mar 11, 2009 at 1:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get both tires off the ground. I use a 1" pipe 18" long to turn the spanner.....Watch your knuckles..:(
  11. Mar 11, 2009 at 1:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, they are a bitch. One of the reasons I dont run them anymore...:eek:
  12. Mar 11, 2009 at 1:50 PM
    LonghornTaco
    Minnesota
    I just take 'em off. Not that difficult and it makes the adjustment SOOO much easier...
  13. Mar 11, 2009 at 6:47 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    okay. so no magic bullet. I'll get the pipe or either remove them to adjust tomorrow. O will update then.....
  14. Mar 12, 2009 at 6:55 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    got it done! PB blaster and some 1" pipe from home depot got the job done. thanks guys.
    got the front height the same between RT and LT and cranked it up some too. Now i have to find some new wheels and tires. debating between 285/75/16 and 285/70/17
    i just put some FJ sport 17" wheels on there with stock tires to see how it looks. the tires are so small after taking off my 285/75.
  15. Mar 12, 2009 at 6:56 PM
    LonghornTaco
    Minnesota
    sweet! :thumbsup:
    Go 285/75 - more tire, less wheel!
  16. Mar 12, 2009 at 7:12 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    yeah. that is what came off. just wanna consider all options.
