Rubbing issue with 266 75 16
Discussion in '1st Gen. Tacomas (1995-2004)' started by fpradojr36, Jul 9, 2010.
  1. Jul 9, 2010 at 9:51 PM
    fpradojr36
    fpradojr36 [OP] Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    Ok. So I got a problem. I bought some bfg all terrain 265 75 16 with some 16x8 procomp 87 series rims. I do not have a lift, but from what I heard and read on forums it doesnt rub too much and will not affect ride too much. So I installed them at work. As soon as I backed up from stall and turned steering wheel is when I heard tire messing up my plastic inner fender liner. I took off fender liner thinking that was problem, to see that the weld sticking out was rubbing against tire. I did not want to risk messing up brand new tires, so I took them off. Has anyone with 1st gen tacoma came across this problem? I will and now have to get lift, but money is issue right now. I was thinking about laser cutting a portion of that weld off and see how it works any thoughts from anyone will be appreciated.
  2. Jul 9, 2010 at 10:07 PM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    ive got the same size in toyo AT and mine arent even close to rubbing but my rims are 15 dumb question but the rim doesnt affect the tire size does it? but if you have to get a lift then for now get levelin spacers until you can get some bilsteins
  3. Jul 9, 2010 at 10:12 PM
    fpradojr36
    J.R.
    90804
    I don't think the rim has anything to do with problem. The tires are soo beefy that it touches pinch weld. I would get spacers, but i'm the type that hates doing a job twice. I may have to though because the tires I have now are in pretty bad shape. I also may look into cutting some of the pinch weld off.
  4. Jul 9, 2010 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Just take a 5lbs carburetor hammer to it. :D Pound that weld flat!
  5. Jul 9, 2010 at 10:28 PM
    fpradojr36
    J.R.
    90804
    I may just do that until I save more money to get toytec lift.
