Rubbing issue with 285/75/16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pojo82, Feb 5, 2010.
  1. Feb 5, 2010 at 5:41 AM
    pojo82
    pojo82 [OP] Well-Known Member
    Josh
    NE Wisconsin
    06 TRD double cab
    flowmaster exhaust, URD cold air intake, URD MAF calibrator, Thorley Headers Billy 5100s set to 2.5 lift in front, Billy shocks with add a leaf in the rear Wet Okole seat covers
    I recently put Billy 5100s all the way around and set the fronts at 2.5". I got ATX Artillary rims. From looking up on this site I found that the backspacing of these rims should work with 285s. I needed to remove my front fender flares to keep them from rubbing. Any ideas of what to do, I do not want to put wheel spacers on. If anybody else went through this id like to hear some opinions and see some pictures.
  2. Feb 5, 2010 at 5:43 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Welcome to TW! What is the backspacing and offset of the rims? Also, you'll need to trim some of the fender and wheel well lining to fit 285s. It shouldn't be too much trimming and nothing that a dremel with cutoff wheel couldn't handle. That's how I did mine.
  3. Feb 5, 2010 at 5:43 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You had to remove the fender flares?
  4. Feb 5, 2010 at 7:36 AM
    pojo82
    Josh
    NE Wisconsin
    06 TRD double cab
    the backspacing is 4.5". i have a trd sport and the front fender flares would rub when the wheels were turned. tire shop said they would cut them for me but i thought if i was going to cut them id do it myself and told them just to remove them. these were my options I was thinking about:
    -leave front flares off (it dont look to bad this way)
    -cut the flares (worried about them "flopping in the breeze" with less support)
    -get different flares (might still have same problem after spending the money)
    -put on a body lift (I kinda like the stance of the truck now not to sure on how it would look another 3" taller)
  5. Feb 5, 2010 at 7:39 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Well, body lifts aren't the greatest option. You'll learn that there are probably about a 100 other members (probably more) who run the 285 tire and we all had to slightly cut our fenders. It doesn't make them any weaker, and unless you own a Tacoma or know what the inner fenders look like, nobody can even tell that you cut them. Especially if you do a clean job.
  6. Feb 5, 2010 at 7:41 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    can you post a pic please?
    i have 33x12.5 r 17 w 4.5 in backspacing and all i had to do was trim the inside fender plastic.
    i have 3 inches of lift but with the bigger tire i assume its close to the same ratio as ur 2.5 in lift with 285/75/r16
    even offroading i didnt have that much rubbing. i will have to cut the body mount at some point but even now there is on;y a little bit of rubbing in reverse
  7. Feb 5, 2010 at 7:43 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Are you talking about fender flares or mud flaps. Most people have to remove mudflaps, but I have never seen anything about fender flares. Some plastic in the wheel wells have to be trimmed as well. I try and find the link.
  8. Feb 5, 2010 at 7:45 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  9. Feb 5, 2010 at 7:55 AM
    Brunes
    Brunes abides.
    Rotorhead
  10. Feb 5, 2010 at 8:07 AM
    jonny
    jonny Betty White Edition Heep ZJ
    took the fender flare off for 285's? doesnt soind right IMO. i have 285's 5100's set @ 2.5 and after minor, and i mean minor trimming. my wheels just rub at full lock in reverse on the cab mounts. weird man.
    in for final verdict
  11. Feb 5, 2010 at 8:28 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
  12. Feb 5, 2010 at 8:36 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    agree. found some pics of my trim job, but you won't have to cut nearly as much since you're running 285's. i have 305's. there's no reason to look for different fender flares, just trim what you need to
    before
    after
    cab mount chop (before)
    after
    if you're worried about the fender insert flapping around, just brace it to the frame like this
  13. Feb 5, 2010 at 8:48 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    << nice pics Klipp.
    Pojo, lets see some pics of those new SWEET rims..I just ordered the AX184s..can't wait.
  14. Feb 5, 2010 at 10:58 AM
    pojo82
    Josh
    NE Wisconsin
    06 TRD double cab
    I didnt get into detail with the tire shop on how bad it rubbed, just told them remove em and ill deal with it this weekend. some minor triming is all I probably need to do. Thanks everybody for the advice Ill try to post some pics after work today.
  15. Feb 5, 2010 at 11:24 AM
    hashemg
    Eastern MA
    Ok so wait. i think you are confusing the inner fender plastic with the fender flare (the piece on the outdise of the fender painted the same color as your truck probably)
    if you removed the inner fender plasitic piece..then yea just trim it down and put it back in. hopefully they save the clips and screws for you
  16. Feb 5, 2010 at 1:45 PM
    pojo82
    Josh
    NE Wisconsin
    06 TRD double cab
    dont look as bad as they made it seem. probably only gota do what zak808 had link for.
    before
