Rubbing Issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aj2439, Aug 25, 2020.
  1. Aug 25, 2020 at 12:32 PM
    aj2439
    aj2439 [OP] New Member
    Andrew
    2019 White Tacoma TRD Offroad
    Prinsu roofrack TRD Pro Grille with Raptor lights Ditch lights Light bar Front camera
    I am looking to do a 3-inch lift with my 2019 Tacoma and was wanting to put 285/70R17 tires on. Does anyone know if I should be good or will probably end up having to do a chop?
  2. Aug 25, 2020 at 12:33 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Cmc needed
  3. Aug 25, 2020 at 12:34 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    You'll wanna cmc and trim the inner liner and lose the mud flaps if you have them!
  4. Aug 25, 2020 at 6:06 PM
    Usstaco
    Usstaco Member
    Austin
    2019 cement taco #usstaco
    i just did a 2" in the front and 1" in the back and i have zero rubbing with 285/70/17 and +1 offset on the wheels. now if you are going to be taking it out on trails you may run into issues but if it is just going to be used mainly on the street you should be fine.
