Rubbing me wrong 265/75R16 with 2.5" of lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crux, Nov 22, 2017.
  1. Nov 22, 2017 at 6:48 AM
    crux
    crux [OP] Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    So I have Fox coilovers set running about 2.5" of lift with 265/75R16 and rubbing the left front wheel well nearly any time I'm turning left. Rims are the TRD beadlocks (fake beadlocks)
    Any suggestions on why this would be rubbing?
    I'd like to go 255/85R16 but concerned that a cab chop might not be enough
  2. Nov 22, 2017 at 6:52 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Where are you rubbing?
  3. Nov 22, 2017 at 6:52 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    what's your caster numbers on alignment?
    bski22 likes this.
  4. Nov 22, 2017 at 6:52 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Replace the upper control arms? And do an alignment
    jeff b likes this.
  5. Nov 22, 2017 at 6:53 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Subbed.
  6. Nov 22, 2017 at 6:55 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I have 265 75 R16’s on stock suspension with no rub. I only had to remove the mini front mud flaps. Seems to me an alignment check is needed.
    Shayaanahmedd_ and jeff b like this.
  7. Nov 22, 2017 at 6:58 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Do you still have the front mud flaps on? Sometimes just removing those will eliminate minor rub. I only have 2" lift running 255/75/17 tires on stock TRD Sport rims which is a 32" tire. No rub at all, so I'm thinking if it isn't the front mud flaps, it's probably due to the wheel offset?
  8. Nov 22, 2017 at 7:02 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Are you rubbing yourself in Public places?
  9. Nov 22, 2017 at 7:02 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    probably rubbing the liner. 265/75/16s shouldn't give you an issue its on .4 of an inch over factory size
  10. Nov 22, 2017 at 7:07 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    OP do you have after market uca's?
  11. Nov 22, 2017 at 7:10 AM
    jpereira2
    Massachusetts
    Actually depends on tires. Nominally 1.04 in. But depending on actual tire dims the largest 265/75/16 is the Cooper St maxx which measures 32" and the factory rugged trails measure at like 30.6 or somethin so almost 1.5"
  12. Nov 22, 2017 at 7:20 AM
    crux
    New Mexico
    OR
    More details as I see it is more complex than initially thought.
    - Tires are the Cooper ST Maxx
    - Upper control Arms are from All Pro
    - Lower control Arms are stock
    - Mud flaps removed long ago
    - Alignment has been done via Firestone (Twice now)
    Rub is on the lower corner of the plastic fender flare. I can take a picture this evening, but here is a side profile of the truck even though this is the passanger side v drivers side
    dziner, bski22 and jztacoma like this.
  13. Nov 22, 2017 at 7:23 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I had similar rubbing while stock with 265/75/16s on the same wheels, BFG KO2s. It wasn't bad, I let it go and it rubbed through the plastic. It's not the biggest issue I've had by any means.
  14. Nov 22, 2017 at 7:24 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    What do ur caster numbers look like? To minimize rub you'd want them at least 3 degrees IIRC.
  15. Nov 22, 2017 at 7:25 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Don't want to assume, but you don't have wheel spacers correct? I rubbed the same spot on my last truck with 265/75R16s but that was because of the backspace I had on the Level 8 MK6 rims (4.1inch back spacing). It could be you have to much wheel backspace and its pushing the wheel to far out. Could go back to firestone and see if they'll increase the caster to push the wheel farther forward in the wheel well.
    *Edit: Nice looking Tacoma btw
  16. Nov 22, 2017 at 7:26 AM
    geekhouse23
    Cut the plastic until you don't rub :notsure:
  17. Nov 22, 2017 at 7:31 AM
    la0d0g
    running for the hills
    For crawling not hauling
    This makes too much sense.
  18. Nov 22, 2017 at 7:51 AM
    crux
    New Mexico
    OR
    Agreed, this is an option.
    However my friend has a very similar set up on 285 with zero rub. Why? is the question
  19. Nov 22, 2017 at 7:54 AM
    geekhouse23
    I doubt he doesn't have any rub.
    ChemDawg likes this.
  20. Nov 22, 2017 at 7:56 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    It works though
    o_O
    geekhouse23 and la0d0g[QUOTED] like this.
