Rubbing of my 285/75/16
Discussion in 'Wheels & Tires' started by lepedog23, Sep 29, 2010.
  1. Sep 29, 2010 at 7:24 PM
    lepedog23
    lepedog23 [OP] Taco Rookie
    Frank
    Huntington Park
    Wrecked 2002 4Runner 4x4 trying to rebuild ***Sold2001 DC Tacoma. Stock. Salvage Title MOD.
    Wrecked 2002 4Runner 4x4 ***Sold 2001 Tacoma, Salvage Title MOD. ***Sold 2010 Tacoma doublecab prerunner
    i finally mounted my 285/75/16 and the wheels are 4.5" backspacing, i trimmed the front and no more rub, but the back is hitting the mudflaps... ive read on here that i will have to trim the cab frame to get no rub want to make sure, dont really want to put a grinder to the cab mount but dont want the rub, also if i remove the spidertrax will it rub more or less? i have a 2.75" spacer lift from readylift.
  2. Sep 29, 2010 at 7:37 PM
    Doc Holliday
    Doc Holliday Yota freak
    I put a 3" lift, 18" rims with 4.53" BS and 285/65/18 tires and removed the front mudflaps and it doesn't rub at all on the back. I just trimmed the front flare and inner fender and it's fine. I also don't have any spacers.
  3. Sep 30, 2010 at 12:42 AM
    lepedog23
    Frank
    Huntington Park
    cool going to remove flaps tomorrow hopefully thatlll work i dont have a jack to try it without the spidertrax.
  4. Sep 30, 2010 at 12:45 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    285 = good bye front mud flaps
  5. Sep 30, 2010 at 9:02 AM
    lepedog23
    Frank
    Huntington Park
    i just took them off but i see it rubs a little on the frame, is it safe to grind off about 1/4" from the frame and just paint it so it wont rust?
    i have total chaos uca's havent installed them will that help? i already put on spidertrax in front.
  6. Sep 30, 2010 at 9:09 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    frame? I'm assuming you're talking about the cab mount, most people chop the cab mount... I'm not exactly sure what is needed to do that, but I'm sure there is a couple write ups around here.
    the spacers will probably only make it worse
  7. Sep 30, 2010 at 9:11 AM
    jusmac
    jusmac Well-Known Member
    wait!!! rubbing on the frame or the cab mounts? You can notch the cab mounts so it doesn't rub, but i wouldn't go grinding on the frame. what lift do you have? i have 285/70/17 and a 17x9 with a -12mm offset rim and mine doesn't rub one bit.
  8. Sep 30, 2010 at 9:18 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    you can see how the cab mounts were cut and filled on my build.
    http://www.tacomaworld.com/forum/2nd-gen-builds/114029-netmonkeys-build.html
    specifically:
    this is a before pic of the body mount and the plastic inner fender well.
    this is the after pic of the body mount chop and trimming on the inner fender well. you can also see that the inside of the fender was trimmed too.
  9. Sep 30, 2010 at 9:21 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    have you wheeled your truck yet? I had the same setup as you and my shit would rub when going over stuff ofroad when turning.
    also adding spidertrax made it 10X worse.
  10. Sep 30, 2010 at 9:34 AM
    lepedog23
    Frank
    Huntington Park
    i am going up to gorman this weekend so thats why i put the 285 that i had bought a month ago. yeah it is rubbing slightly on the cab mount not frame. i have 2.75" readylift spacer, i have some total chaos uca's but dont know if that'll help i havent installed them yet.
    so should i remove the spidertrax? wont that make the tires go more in and therefore more rubbing????
  11. Sep 30, 2010 at 9:40 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    the spacers push your wheels out... so when you turn it is more likely to hit the cab mount
    does it rub while driving straight?
    you could always do what I did to avoid it.... get more lift! :D
  12. Sep 30, 2010 at 9:57 AM
    jusmac
    i would say you def need more lift for 285's. 99% of spacer lifts aren't true to their size. you need a full 3" to have no rubbing with a 285. I did a 3" revtek kit on a buddies truck with 285's and it rubbed so i talked him into a 3" coil over kit and poof no rubbing.
  13. Sep 30, 2010 at 9:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    before my spacers the tires would barley clear the cab mounts at full turn.
    adding the spidertrax pushed the wheel out, but at even a quater turn the wheel no longer tucked behind the cab mount, now it rubbed on the whole thing.
    think of it this way. the spidertrax sticks your wheel out 1.25 inches with the steering wheel pointed straight, turn your wheel and now those spacers are pushing your wheel 1.25 inches back into your cab mounts.
  14. Sep 30, 2010 at 10:04 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    You should be fine with a little cutting. I didn't have any rubbing with my 285s and 3" of lift.
  15. Sep 30, 2010 at 10:11 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    this is why i went with 265/75/16's...
  16. Sep 30, 2010 at 2:35 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yes, before you do anything else, take off the spidertrax!
    a 1.25" spidertrax on a 0mm offset wheel is the same as changing to a -30mm (!) offset wheel. Think "deep dish wheels."
    Large negative offset increases the radius of the arcs the front wheels swing through as the steering wheel is turned from lock-to-lock. And that will increase rubbing at the inner fender well.
    So what are the spidertrax for? Well, with a too large a backspacing (e.g. factory or TRD wheels) wider than stock size tires will rub the UCA. But that can be corrected with a 1/4" spacer. Also, some folks like the "look" of the wider-track-deep-dish stance.
    Bottom line - try removing the bolt on part before you go irrevocably cutting your cab mount.
    And I don't understand this "don't have a jack thing." If you're gonna run off-road, you *need* to be able to change your tires.
  17. Sep 30, 2010 at 5:09 PM
    lepedog23
    Frank
    Huntington Park
    what did you cut it with? or where did u take it to get done?
  18. Sep 30, 2010 at 5:11 PM
    lepedog23
    Frank
    Huntington Park
    doesnt hit anything while driving straight, i trimmed both front & rear but hits the cab mount when making turns and hit a bump/dip or while going up my driveway while making a turn.
  19. Sep 30, 2010 at 5:12 PM
    lepedog23
    Frank
    Huntington Park
    going to go buy a floor jack tomorrow and removing the spidertrax and putting them in rear.
  20. Sep 30, 2010 at 5:14 PM
    lepedog23
    Frank
    Huntington Park
    yeah im going for my first time on saturday so going to pick up a floor jack tomorrow @ harbor freight.... plus a couple of other accessories.:D
