Rubbing on UCA, New UCA/Spacer Fitment Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RockingTaco805, Aug 17, 2025.
  1. Aug 17, 2025 at 7:42 PM
    RockingTaco805
    RockingTaco805 [OP] Member
    2020 TRD OR 4x4
    285/75 R16 BFG AT KO3 6112s Front 5100s Back AWE Exhaust S&B Intake
    Hey guys new to the group and looking for some help on the best solution.
    I have a 2020 TRD OR 4x4 with 6112’s with 285/75/16 on stock wheels.
    No rubbing anywhere really but the UCA.
    Happy with my stock wheels for now so wondering if new UCA would fix this?
    I know wheel spacers will help move the tire away and most people are not a fan and to use a trusted brand like spider trax.
    What’s the best fix here?
    Ricardo13x likes this.
  2. Aug 17, 2025 at 7:48 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  3. Aug 17, 2025 at 7:58 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    If you want to keep the +25 offset wheels, you will need to get minimum spacers to keep a clear full turn. 3/4" bolt ons are the smallest bolt ons, I am aware of. BORA makes a 10mm (<1/2") slip on spacer but you need to replace the front lug bolts with longer ones.
  4. Aug 17, 2025 at 7:58 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    tubular uca like icon will clear. some like spc and jba will not. a 3/4" bora spacer is the best route. start going any wider and your wheels will be rubbing the body.
  5. Aug 17, 2025 at 8:21 PM
    RockingTaco805
    2020 TRD OR 4x4
    Thank you I wasn’t aware of the 3/4 size offered by Bora.
    I was going to get some spidertrax 1.25” but that will probably fix the one issue with the UCA but then cause another issue because I’ll probably start hitting the cabmount and need a chop.
  6. Aug 18, 2025 at 6:29 AM
    jmferg
    jmferg Well-Known Member
    I would get a 1/2" spacer and get extended studs. You can always get a tubular UCA. Is it rubbing at lock in reverse?
  7. Aug 18, 2025 at 6:45 AM
    Krustycrab
    Krustycrab Member
    Macklyn
    baton rouge
    2022 TRD off road 6MT & wife's 2011 Tacoma trd sport
    i will be paying attention to this thread. i have some 16in FJ cruiser beadlock wheels(which are +10 i believe) and wanna go with 285s. currently on 275/70/17 w/ 0 offset wheels. stage 10 icon suspension w/ billet UCAs
  8. Aug 18, 2025 at 3:46 PM
    devinzz1
    devin
    2023 aclb trd or mt
    +10 and 285s clear with stock uca. id assume they do with the icon billets aswell.
  9. Aug 18, 2025 at 9:52 PM
    RockingTaco805
    2020 TRD OR 4x4
    One thing to consider with the thickness of spacers that I recently learned is the length of the stock studs. If you put a spacer on shorter than the length of the stock studs you will have to cut the studs down.
    Does anyone happen to know the length of the stock studs?? The part that sticks out. The total length is 40mm or 1.5” I am seeing
  10. Aug 18, 2025 at 10:10 PM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I have the 3/4" bora spacers for about 4yrs now. 0 offset 17x8.5
    JBA UCA 35/12.5/17s, no rubbing full-lock. Minor rubbing on reverse though.
  11. Aug 18, 2025 at 10:16 PM
    RockingTaco805
    2020 TRD OR 4x4
    Ok awesome! You’re running some big tires too. Did you have to trim the stock wheel studs to get the wheels mounted correctly with the 3/4” bora spacers?
  12. Aug 18, 2025 at 10:43 PM
    Sig Taco
    2021 Taco DCSB
    No my icon wheels have grooves on the inside to accommodate the studs
    RockingTaco805[OP] likes this.
  13. Aug 18, 2025 at 11:32 PM
    RockingTaco805
    2020 TRD OR 4x4
    Thank you! I’ll ad pictures to the thread when I get them and get them on.
  14. Aug 20, 2025 at 2:51 PM
    Krustycrab
    Krustycrab Member
    Macklyn
    baton rouge
    gracias!:thumbsup:
