Rubbing on Upper Control Arms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AuraTRD202-, Nov 21, 2024.
  1. Nov 21, 2024 at 2:18 PM
    AuraTRD202-
    AuraTRD202- [OP] New Member
    2021 TRD Off Road Tacoma
    Readylift 3inch front 2 inch read
    Hey guys. Very new to this and with my truck. Got a ready lift installed (3 inch in the front and 2 inch on the rear) and had 33’s installed. I noticed that when I crank it to the left or the right, I noticed rubbing and noticed that the rubbing is on the upper control arms. Other than that driving it is smooth on the road but I have to go wide on my turns to avoid rubbing. Any tips on what should I do with the rubbing?
  2. Nov 21, 2024 at 2:46 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  3. Nov 21, 2024 at 2:59 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  4. Nov 21, 2024 at 3:01 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Step 1 what 33 and what wheel specs. 285/70r17 285/75r16 or 33x12.5. Stock wheels?
  5. Nov 21, 2024 at 3:02 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Wheel spacers or aftermarket wheels with more offset than what you currently have installed.
    MGMDesertTaco and SH10151 like this.
  6. Nov 21, 2024 at 3:04 PM
    AuraTRD202-
    The new tires are 285/75r16. And yes the wheels are stocked
  7. Nov 21, 2024 at 3:05 PM
    Veet-88
    That'd be your problem. The wheel offset is likely to positive to accept the wider tire
    BillF1564 likes this.
  8. Nov 21, 2024 at 3:10 PM
    AuraTRD202-
    I see. Someone above said new wheels or wheel spacers. Which on do you recommend?
  9. Nov 21, 2024 at 3:57 PM
    BillF1564
    2021 Tacoma SR
    :popcorn:
    Maybe take it back to whoever installed the lift and ask them?
  10. Nov 21, 2024 at 4:29 PM
    Veet-88
    Lots run spacers without issue but I personally will always change wheels to the offset I'm after. I would be aiming for a 0 offset as it offers the best of bolth worlds for tire clearance, but not so far out it's compromising cab mount clearance
  11. Nov 21, 2024 at 9:37 PM
    AuraTRD202-
    Ohh okay. So as I mentioned, driving is smooth on the road. On turns I don’t rub unless I crank it to the left or right. As of right now I should be okay with just daily driving right? Money is tight right now and I do plan on solving this problem with new wheels in the future. But as of right now I shouldn’t have to worry about any damage correct?
  12. Nov 21, 2024 at 9:49 PM
    MGMDesertTaco
    No, take it back to the shop.
    Bora wheel spacers are quality pieces. Otherwise order a new set of wheels with a zero or negative offset.
    oem trd wheels are +25 offset.
    edit: 1.25 wheel spacers will get the tire off the uca, but you'll likely have some rubbing on the plastic. Spidertrax or Bora wheel spacers are recommended brands.
    https://www.tacomaworld.com/threads/285-75r16-33’s-on-stock-rims.762002/
    timw1, STEELeR43 and blacktaco77 like this.
  13. Nov 22, 2024 at 1:15 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Also keep in my that if you have 7” wide wheels you might be outside the width range recommended by the tire manufacturer. I think 7.5-9” is generally recommended for 285’s.
    There are 7” and 7.5” width stock wheels.
    Also note that more offset might fix the UCA rubbing issue but cause cab mount rubbing which might require a CMC to fix.
    This thread is for 315mm 35’s, but many of the topics apply to 285mm 33’s to a lesser extent.
    https://www.tacomaworld.com/threads...-those-that-wheel-and-love-alignments.594309/
    As an aside, is there a quality write up for 285mm 33’s on TW?
