Rubbing tires in the past, future problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sg4506, Jan 13, 2011.
  1. Jan 13, 2011 at 10:27 PM
    sg4506
    sg4506 [OP] Member
    Andrew
    Anchorage
    '11 TRD offroad
    3" RevTek lift, Poweraid throttle body spacer, K&N Aircharger, 8000k Headlights and foglights, 2" aluminum wheel spacers
    Hey guys,
    I had an '06 SR5 tacoma with a 3" RevTek lift and when my tires (285/75/16 BFG All-Terrains on a 12x16 rim) were at full lock they would rub on the sub frame on the back of the fender. Well I have an '11 TRD Offroad Tacoma now and I'm wondering if I'll have the same problem. I've got stock size studded tires on now, otherwise I'd be able to answer this question for myself. Any ideas on what I'll be expecting come late May?
  2. Jan 13, 2011 at 11:40 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Why are you running a tire that is 11.22 inches wide on a 12" wheel? What is your back space on these?
  3. Jan 14, 2011 at 6:05 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    :eek: 12" wide rim?!
    Going for the Hawaii look in Alaska?
    There's no difference in suspension/frame between 06 and 11. If you rubbed in your '06, you will on the 11.
    I'd suggest some 8 or 9" wide rims with 4.5" backspacing to run 285's.
  4. Jan 14, 2011 at 1:36 PM
    sg4506
    sg4506 [OP] Member
    Andrew
    Anchorage
    '11 TRD offroad
    I apologize guys. I just checked the specs online and I thought they were 16x12 but in reality they're a 16x10 with a -25mm offset. I also have 2" bolt on spacers.
    On my '06 they would rub at full lock in reverse but not in drive. Also anytime I hit any sort of bump in the road if my wheel was turned about 1/2 way they would pretty much "bark" at me. Kind of a neat sound, but I think I'm going to have to replace the tires sooner than I expected, the outside tread is starting to wear because of it.
    Any suggestions on a lift? I know that would fix my problem. My current lift is a 3" RevTek that's pretty much just a big hockey puck shoved under the spring. Good think about that is if I get a lift that's new springs and/or A-arms I don't have to toss the 3" spacer, correct?
  5. Jan 14, 2011 at 3:13 PM
    KPT
    09 Prerunner
    If you ditch the 2" wheel spacers, that will cut down on the rubbing. The -25 offset with the 10" wheels is 4.5" backspacing, which is ideal for running 285's with a lift. Having the spacers on there pushed the wheels out 2" futher, causing them to have a wider path when turning, leading to rubbing.
    If you get new springs you DO have to remove the spacer.
    Stacking lifts is a big no-no. Your UCA's and ball joints can't handle much more than 3" of total suspension lift without a drop bracket.
