Rubbing tires
Discussion in 'Suspension' started by 06 tacoma owner, Nov 26, 2012.
  1. Nov 26, 2012 at 3:10 PM
    06 tacoma owner
    06 tacoma owner [OP] Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    My tires are oversized and the tread on the side of the tire rub on the upper control arm and I am wanting advice on fixing this without replacing the tires.
  2. Nov 26, 2012 at 4:44 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Try wheel spacers?
  3. Nov 26, 2012 at 4:52 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Wheel spacers are the lowest-cost solution, though they increase the tire's scrub radius, so you may need to trim the fender flares a bit more.
  4. Nov 27, 2012 at 4:50 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Rims with 4.5" back spacing is ideal but spacers will work with some rubbing (depending on tire size) as a side effect!
  5. Nov 27, 2012 at 4:59 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    or new rims.
  6. Nov 27, 2012 at 12:41 PM
    WiR3D
    WiR3D Well-Known Member
    James
    Clearwater, FL
    06 PreRunner SR5 TRD DCSB
    Im running 285/75R16 on my truck with a 3in OME lift. I was rubbing on my UCAs pretty good and ended up getting a set of Spidertrax 1.25 spacers off a member here. I do recommend it! You will however end up having to cut away at your inner fender well which to me wasnt an issues as its just a minor piece of plastic nobody will really see.
  7. Nov 27, 2012 at 12:53 PM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    new wheels with 6mm backspacing
