Rubbing/Trimming with 285/70/17 Duratracs
Discussion in 'Wheels & Tires' started by GbonifaziDPT, Sep 11, 2016.
  1. Sep 11, 2016 at 5:02 PM
    GbonifaziDPT
    GbonifaziDPT [OP] Member
    Gian
    Chicago
    2015 Pyrite Taco
    Hey all!
    So I've got a 3" OME lift and have already gotten the CMC done. I've got new wheels ordered (17x9, -12 offset, 4.5" backspacing) and will be getting 285/70/17 Duratracs. I've been looking around the forums and have not really found a solid answer regarding possible rubbing as it seems some say there will be rubbing and some say there won't be. I'll likely have to trim some of the rear on the front fender, but in your experiences, have you had to trim/mod any other areas to make sure there is no rubbing? Ie: pinch weld, front plastic fender protectors, etc. Any advice would be good. Worst case scenario will be to just find out where the tires are rubbing when I get them on and go from there haha. Thanks in advance!
  2. Sep 12, 2016 at 8:36 PM
    YOTA 209
    YOTA 209 Instagram: Yota_209
    Stockton/Lodi CA
    2005 DCSB TRD off-road
    Lift - 887 OME/Bilstien 5100s LR UCA Dakar full leaf pack/Bilstien 5100s Tires - 285/70R 17 BFG KO2's Wheels - ProComp 5001's 17x8
    Bump from another inquiring TW member
  3. Sep 15, 2016 at 6:27 AM
    Carl74
    Carl74 Member
    Carlos
    2015 Black Tacoma TRD Off Road DC 4x4
    XSP-X 17" Rims with BF Goodrich Rough Terrian
    Your tires will clear, at least as far as your UCA's go. You may require some minor trimming but nothing that is noticeable or difficult. And that is dependent upon the type of tires you run, all tires are not the same. With your backspacing of your new rims you are pulling the rim out away from the upper control arm, giving yourself more space for tire. A 285 will clear on your 4.5" back spacing and -12 off set. Post a pic of the tires when you get them installed and show off that Tacoma.
