Rubbing w/ 285s after TC UCAs
Discussion in 'Arizona' started by Cannonball, Dec 21, 2012.
  1. Dec 21, 2012 at 4:54 PM
    Cannonball
    Cannonball [OP] Well-Known Member
    Justin
    Phoenix
    2012 F-250 FX4 6.7 diesel / 1979 Jeep CJ-5
    I decided to finally install my total chaos UCAs this past weekend. Got an alignment and it is driving great as long as I don't have to turn. Caster is 2.5, camber and toe are just about 0. The UCAs and alignment brought the wheels rearward in the well and now I'm getting some bad rubbing on the rear fender well and probably cab mount. I have 885s on 5100s set at 0. Tires are duratrac 285s on FJ wheels. Aargh, what to do? :confused:
  2. Dec 21, 2012 at 5:00 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    When I added mine the same thing happened.......shop suggested a cab mount chop and pinch weld mod since i wheeled the truck. That helped but I also had to get another alignment and had them add more caster from the lower control arm, basically pulling the tire forward from the bottom! Still ended up with 2.5-2.8 caster?
  3. Dec 21, 2012 at 5:01 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    I'm not an expert on this but you may need some wheel specers
  4. Dec 21, 2012 at 5:14 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Wheel spacers will make it worse. Looks like you gatta do the cab moubt chop OP. i just did it today to fit my 285 duratracs.
  5. Dec 21, 2012 at 5:20 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Completely normal.
    By adding UCA's you are able to get the 2.5* caster. The downside is it will rub the pinchweld as you are intimately familiar with. Don't so spacers as they will push the wheels out farther and rub the pinchweld even more. You just need to do a cab mount chop and you'll be all set.
    Great looking truck BTW too!
  6. Dec 21, 2012 at 5:49 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Heres what i did today. Trimmed the bottom of the fender, cut the plastic wheel well liner back, bent the pinch weld over and cut the cab mount. I don't have a welder or have much welding experience so i will probably run it like this for awhile until i find someone to box it for me.
  7. Dec 21, 2012 at 6:27 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Sorry I misread what the op was asking I though he was rubbing on his uca
  8. Dec 21, 2012 at 6:30 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    X2. Also with those 285's you'll have to cut some plastic, but looks like you already took care of that
    Edit: sorry different person posting. You'll have to cut some plastic as well
  9. Dec 21, 2012 at 6:32 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Ya i have that problem alot also of just skimming through the post haha. In your defense the words rubbing and UCAs are in the title lol.
  10. Dec 21, 2012 at 6:37 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    ^^ Yup......Avid will chop the cab mounts for cheap! Got mine done at Desert Rat since they were close and only charged $150 and included welding plates back in and paint!
  11. Dec 21, 2012 at 7:03 PM
    Cannonball
    Justin
    Phoenix
    Thanks! I'll see when I can get out to see Brandon. I may check out Sierra exp or Sonoran steel as well since they are closer. I might also throw the 265s on until I can get the chop done.
  12. Dec 21, 2012 at 7:05 PM
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    Same thing happens to me. Adjust the caster slightly. Better to have your tires wear slightly off than cutting the cab mount IMO.
  13. Dec 21, 2012 at 7:13 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Caster is not a tire wearing angle.
  14. Dec 21, 2012 at 7:15 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Thats how i left mine....only had to cut one lol
  15. Dec 21, 2012 at 7:18 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    He means the tire wearing from rubbing on the cab mount i believe
  16. Dec 21, 2012 at 7:44 PM
    creedler
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    Yep thanks for clarifying.
  17. Dec 21, 2012 at 8:35 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    This is normal. Cab mount, pinch weld, wheel spacers, and trimming. Thats all thats going to solve it... That or fiberglass fenders. Just the facts of life boys and girls.
  18. Dec 21, 2012 at 8:39 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Shit.....I've heard of some trucks having upwards of 4* caster with a tube bumper just to keep the wheels out of the firewall!
  19. Dec 24, 2012 at 3:56 PM
    Cannonball
    Justin
    Phoenix
    Did some Dremel trimming of the flare and fender liners and I can at least drive around without too much chaos. Still will need to bend over the pinch weld and get the cab mount chopped if I have any hope of wheeling it.
  20. Dec 24, 2012 at 6:46 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Call Brandon at Avid Offroad. He can do both for you real quick. Did mine and a bunch of other peoples. He cuts local AZ guys a hell of a deal.
