Rubbing when backing up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brvermilli21, Oct 1, 2019.
  1. Oct 1, 2019 at 7:11 PM
    brvermilli21
    brvermilli21 [OP] Well-Known Member
    Knoxville TN
    After having my toytec 3" lift on for a few weeks I installed see 1.5" wheel spacers to get my wheels even with the fenders. After driving today to test out the spacers I heard some rubbing of my wheel when trying to back up. Anyone run into this issue? I've running 265/70r17 tires which I think you can run with no lift. Didn't have any rubbing issues before the spacers. Really like the look of the truck with them on so I'd hate to have to remove them but I have to get this rubbing issues fixed.
  2. Oct 1, 2019 at 7:22 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    I have the 265/70-17 tires on my truck.
    The right front tire was rubbing on the small vertical rubber flap in the fender well. I just removed it.
    You need to have someone back the truck up, while you look to see where the tire is rubbing.
  3. Oct 1, 2019 at 7:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    When you added the spacers you changed the backspace by that much. You’ll need to have the caster adjusted to as much positive caster as you can get with the factory ucas ( I assume you didn’t change them.) or you’ll need to remove the spacers.
  4. Oct 2, 2019 at 3:11 AM
    brvermilli21
    Knoxville TN
    I had the upper controls arms replaces with jba arms so the alignment was spot on before the spacers. I'll get someone to back up the truck while I look for areas of rub. Hope it's just a small area I can remove easily
  5. Oct 2, 2019 at 4:02 AM
    gotoman1969
    If the caster was set at factory specs which I believe is 2.5 degrees. You may need a bit more cause of the spacers. Hopefully you can get away with just some slight trimming. Keep us posted.
  6. Oct 2, 2019 at 6:47 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    I rub going in reverse at weird angles sometimes and I have 33s. I know your pain. I’m going to have to do a lot of cutting to fit 35s when the time comes.
  7. Oct 2, 2019 at 6:03 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    pic of ur truck on those 265/70r17's please
  8. Oct 2, 2019 at 6:27 PM
    brvermilli21
    Knoxville TN
    Got some help holding the wheels sharp and found a small area of the fender that was touching. Cut it away and so far so good, even when backing up
    gasgasman likes this.
  9. Oct 2, 2019 at 6:28 PM
    brvermilli21
    Knoxville TN
