Rubbing when hard breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB10thplanetnewport, Feb 12, 2020.
  1. Feb 12, 2020 at 5:25 PM
    KB10thplanetnewport
    KB10thplanetnewport [OP] Well-Known Member
    Kyle
    2015 trd off road
    Hoping to get some advice on where to check/trim for rubbing. I put some 265 75 16 tires on my stock wheels with no issues at all but switched wheels today to some MB Tko wheels and started getting rubbing while turning hard. I removed the front mini (mud flap?) and turning is ok now but I noticed while coming to a hard stop I have rubbing again. Where should I be looking for the hard stop rubbing?
  2. Feb 12, 2020 at 5:28 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Sounds like your coils can’t support the weight of the truck anymore.
  3. Feb 12, 2020 at 5:29 PM
    KB10thplanetnewport
    Kyle
    2015 trd off road
    They did this morning before the new wheels lol
  4. Feb 12, 2020 at 5:31 PM
    KB10thplanetnewport
    Kyle
    2015 trd off road
  5. Feb 12, 2020 at 5:34 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    If it only rubs when stopping hard and not while turning I can’t see it being in relation to new wheels.. I’d start by shaking down the front end and check for loose parts. Or have a look around for marks from the tire scrubbing if that is indeed what’s going on.
    edit to add: how much lift if any?
  6. Feb 12, 2020 at 5:36 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Look for rub marks on in the back of the wheel well.
    Braking*
  7. Feb 12, 2020 at 5:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Maybe the upper control arms?
    Was the offset different from stock wheels?
    308savage likes this.
  8. Feb 12, 2020 at 5:38 PM
    KB10thplanetnewport
    Kyle
    2015 trd off road
    As in the southern part of the wheel well? I was looking in front thinking the truck could slouch forward with a hard braking. I’ll take a look.
  9. Feb 12, 2020 at 5:38 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    What’s the offset of the new wheels compared to the old ones? Check for clearance on the UCA’s.
    TnShooter likes this.
  10. Feb 12, 2020 at 5:39 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Also are the wheels wider then stock?
  11. Feb 12, 2020 at 5:39 PM
    JKO1998
    Utah
    The cab side
  12. Feb 12, 2020 at 5:39 PM
    KB10thplanetnewport
    Kyle
    2015 trd off road
    By the way this is HARD braking not standard driving braking.
    The offset may be different I feel like I read it was a -6
  13. Feb 12, 2020 at 10:14 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I "think" that the standard wheel offset for the Tacoma is +30 unless you have 18" wheels then it is +25. [​IMG]
  14. Feb 12, 2020 at 10:55 PM
    TnShooter
    Deogee
    STOCK
    Jimmyh[QUOTED] likes this.
  15. Feb 13, 2020 at 12:28 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes in the image in my post the # ET30 figure represents a +30 Offset.
  16. Feb 13, 2020 at 12:28 AM
    KB10thplanetnewport
    Kyle
    2015 trd off road
    So what does this mean if I have -6? I need spacers?
  17. Feb 13, 2020 at 12:31 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    This will explain wheel offsets for you.
    https://www.tsw.com/explore-tsw-custom-wheels/what-is-wheel-offset.php
    The Tacoma uses a +30 offset stock. When you went to a negative offset -6 the wheel sticks out more away from the vehicle center line. In otherwords it is like you already have a spacer installed.
    TnShooter and EdgemanVA like this.
  18. Feb 13, 2020 at 12:51 AM
    KB10thplanetnewport
    Kyle
    2015 trd off road
    Wouldn’t that help it rub less?sorry I’m brand new to this.
  19. Feb 13, 2020 at 4:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Not necessarily.
  20. Feb 13, 2020 at 5:19 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    So are we talking straight line emergency breaking? And the tire is rubbing the fender well or fender flare?
