Rubbing with 1.5 spacers and 285s
Discussion in 'Wheels & Tires' started by deejaecee, Nov 13, 2011.
  1. Nov 13, 2011 at 4:58 PM
    deejaecee
    deejaecee [OP] Well-Known Member
    Bay Area
    10 4X4 Double Cab Sport
    Just installed 1.5 ap spacers and am rubbing on the cab mounts. I have 16" Trd anthracite wheels with 285/75/16 tires and Icon shocks in the front set at 2.5. If I chop the cab mounts can I make these spacers work? Or what do I have to do to not rub on the cab mounts?
  2. Nov 13, 2011 at 5:55 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The TRD FJ wheels already have 4.5" backspacing. If you remove the wheel spacers the rub will be significantly less. You have pushed the wheels out too far by adding spacers to a wheel that already has ideal specs for fitting 285s
  3. Nov 13, 2011 at 6:05 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Do whatever he says. You will not regret taking his advice on anything to do with wheels and tires.
  4. Nov 13, 2011 at 6:06 PM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    sell me the spacers really cheap. :D
  5. Nov 13, 2011 at 7:11 PM
    deejaecee
    Bay Area
    Is there any way to make this work? cab mount chop or by raising the front abit higher? I wanted to push the wheels out farther because I liked the look of it. I couldnt even leave the driveway becaused it rubbed so much. This is even when I barely turned the steering wheel. I ended up removing the spacers because of this.
  6. Nov 13, 2011 at 7:13 PM
    KPT
    09 Prerunner
    Not without hacking up your fenders (the actual fender, not the liner) and getting a custom front bumper.
    You could pull off the fender flares if you want the wheels to look like they stick out further....
  7. Nov 13, 2011 at 7:15 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :laughing:
  8. Nov 14, 2011 at 2:48 PM
    deejaecee
    Bay Area
    It looks like too much work to make these fit.
