rubbing with 285-60/18s?
Discussion in 'Wheels & Tires' started by ozmon420, Dec 7, 2008.
  1. Dec 7, 2008 at 8:20 AM
    ozmon420
    ozmon420 [OP] Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    will i rub with 285-60/18's?
  2. Dec 7, 2008 at 8:21 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Nope you can rund that tire on a stock truck. That tire will be 31.4" tall.
  3. Dec 7, 2008 at 8:24 AM
    ozmon420
    miami, florida
    08 tacoma
    will i have to remove front mud flap?
  4. Dec 7, 2008 at 8:32 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I don't think you will with that tire, but I could be mistaken about that.
  5. Dec 7, 2008 at 10:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You will rub if at stock height. That tire is a 32 x 11.50. I have a 3" lift and get a slight rub when backing up while turning. If I was not lifted, the rub would be MUCH worse. The width of that size tire is going to cause the rubbing.
  6. Dec 7, 2008 at 10:38 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
  7. Dec 7, 2008 at 11:02 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Chris I have a question where are you getting the 32 from? Or are you rounding up? This is how I do it
    285x2= 570
    570x.60= 342
    342/25.4= 13.45
    13.46+18= 31.46
    Just asking.
    I do understand that this tire is slightly wider.
  8. Dec 7, 2008 at 11:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have some friends in the tire industry, and they told me that the tires are "rounded up", i.e. a 31.3" tire is considered a 32", A 30.4" is considered a 31", etc. Tire sizes vary widley from manufacture to manufacture, so one brands 285/60/18 may be 31.4" while another may be 31.7" Some are much larger than what they are listed as being. Goodyear MTR's are regularly larger than how they are sized. Also, as I showed PakerfanXD, tread width can vary as well, depending on sidwall profile. He has 285/75/16's while Im running 285/60/18's, yet my tread was almost a full inch wider from edge to edge.
  9. Dec 7, 2008 at 11:17 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Ok, I was just wondering if you were using a different formula than I. Tire sizes remind me of shoes, a size 10.5 is not the same from manufacturer to manufacturer. Thanks Chris.
    To the OP I appologize for giving faulty info. I honestly thought that tire would have fit, even with the added width.
  10. Dec 7, 2008 at 12:15 PM
    ozmon420
    miami, florida
    08 tacoma
    what is it that u r rubbing on?
  11. Dec 7, 2008 at 12:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I get a little rub on my front mud flap. No biggie, and I have just left it like that.
  12. Dec 7, 2008 at 12:42 PM
    ozmon420
    miami, florida
    08 tacoma
    if i dont raise it what will i be rubbing on
  13. Dec 7, 2008 at 1:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Probably the front and rear of the fender.
  14. Dec 7, 2008 at 2:04 PM
    ozmon420
    miami, florida
    08 tacoma
    what can i do to raise it an inch most inexpensive way?
  15. Dec 7, 2008 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'd say use the Bilstien 5100's to lift it. For about $280.00 shipped, you get front and rear shocks, the front are adjustable to 4 different hieght settings.
  16. Dec 7, 2008 at 5:00 PM
    rkdiddy
    rkdiddy Senior Member
    OC Baby!
    '08 Taco DC PR
    Why don't you just run 265's? Wouldn't that fix the issue of the rub?
  17. Feb 7, 2010 at 7:03 AM
    bravosvo
    bravosvo Active Member
    Isn't 265/60/18 the closest size increase equivalent to stock 265/70/16??
  18. Feb 7, 2010 at 8:15 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW!
    You are correct. 265/60/18's are the closest to 265/70/16.
    I am running 265/65/18's with no issues on stock suspension. These are the same width and diameter as the popular 265/75/16's.
