Rubbing with DuraTracs and DC2s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airun, Jun 29, 2010.
  1. Jun 29, 2010 at 4:01 PM
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Hey gang just got my 265/75/16 duratracs mounted with my dc2s and stock suspension and the truck looks great. However they rub like crazy when turning, so I commenced trimming followed by f it and front mud flap removal. So be warned y'all with increased offset wheels. You'll read all over the place that this size is safe, but only with stock wheel numbers. Mine are +12mm I believe.
  2. Jun 29, 2010 at 4:02 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    you will love the duratracs . i had the same issues going with that tire size. then i went up a lil bit
  3. Jun 29, 2010 at 4:55 PM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    Post up some pics!!
  4. Jun 29, 2010 at 4:59 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    I had the same problem. 265/75/16 duratracs on the DC1s though. Just remove the mudflaps and trim a bit. I used a dremmel to grind out the inside of the flare so it looks smooth and stock. Then I just used some scissors to trim that thin black plastic where it rubbed. No more rubbing :)
    Trimming was extremely minor and quick. I didn't have to dremmel off more than 1/2 inch of the inner flare and about an inch of that thin black plastic.
  5. Jun 29, 2010 at 5:01 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Probably a -12mm offset in order to cause the rubbing.
  6. Jun 29, 2010 at 8:16 PM
    Airun
    Aaron
    Show Me State
    I had driven enough prior to trimming that the flaps were cracked horizontally along where they match up the body, so I trashed em. Just 50 or so mile of driving and I'm hearing a lot of debris bouncing up off body, so I'm a little nervous. I'll see if I can get pics posted. I'm a total tech tard so I probably won't be able to figure it out tonight.
  7. Jun 29, 2010 at 8:25 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I have the same problem too with my 265/70/17 and ^ size offset.
  8. Jun 29, 2010 at 9:23 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    I have the same problem with my DC1's and 265/75/16 tires. I just removed the front flaps and that helped a lot, it still rubs when I cut it hard, especially in reverse. But I can live with it. It isnt hurting anything.
  9. Jun 30, 2010 at 2:52 PM
    Airun
    Aaron
    Show Me State
    ok I'm gonna attempt a before pic:
  10. Jun 30, 2010 at 2:56 PM
    outlawtacoma
    W. TN
    I really like those caps! Is that the main difference between the DC1's and DC2's
  11. Jun 30, 2010 at 3:21 PM
    Airun
    Aaron
    Show Me State
    Here is some lame attempts at after pics. I used an oscillating end-cutting saw that worked perfect on the plactic. No more rubbing but concerned about paint integrity with tires hanging out so far. Stoked about looks. May need bushwackers.
  12. Jun 30, 2010 at 3:21 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Will a lift let you keep your flaps?
  13. Jun 30, 2010 at 3:25 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    That's only one change. The DC-1 spokes are thinner and longer (giving a more elongated gap between the spokes), while the DC-2 spokes are wider and fatter. Personally, I like the DC-2s a lot better.
  14. Jun 30, 2010 at 5:37 PM
    Fluffymonkey
    Fluffymonkey Token
    The dc1s also had the fake beadlock ring around the rim which the dc2 doesn't have.
  15. Jun 30, 2010 at 6:17 PM
    RelentlessFab
    Eric
    Aw man, that aint nothin! Here's some cuttin! :D
    Thats to fit 35's on a 3" lift, but I still need to trim a tad more to completely stop the rubbing while at about 1/2 turn offroad. :cool:
  16. Jun 30, 2010 at 6:19 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    damn OP. The tires are STUFFED in there. Looks like a fawken beast!
  17. Jun 30, 2010 at 6:20 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Time for a set of 5100's set at .85.
  18. Jun 30, 2010 at 6:27 PM
    Airun
    Aaron
    Show Me State
    wow plastic cannibalism! I'm hoping some Billy 5100s with an inch to 1.5" will allow me to go back to some flaps. What do you guys with DTs think of the ride? The road manners are definitely rougher than the forteras I just had and there is a definite whine at hwy speeds, but the aggressive looks I hope are gonna be worth the trade off. The defining factors will be longevity and mpgs. I was averaging 21.5 per tank with 40 pound tires at 40 psi. I'm gonna start these 45 pounders at around 42 to 43 and adjust down from there to find sweet spot with respect to ride and mpg. I expect tires to go 40 to 50k miles which I typically get out of A/Ts.
  19. Jun 30, 2010 at 6:29 PM
    Airun
    Aaron
    Show Me State
    Wow Tim, nice setup. I hope these 2nd gens prove as durable, reliable and long lasting as 1sts, but I have my doubts. Nice rig! U think the 5100s at .85 lift will get my flap clearance?
  20. Jun 30, 2010 at 7:44 PM
    tim920
    Tim
    Boston, MA
    ^Thanks! You're referring to me right? :D
    I think the 5100s set at .85 would stop the rubbing. I'd set it at 1.75 though, or even 2.5 if the alignment can be done can get back to normal specs. I just haven't had a chance to get it lifted yet.
    Sometimes I scare people (walking near me) when I'm backing up in a parking lot. The rubbing makes such loud painful noises. Funny thing is it doesn't rub at full lock.
