Rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, Jan 11, 2010.
  1. Jan 11, 2010 at 9:18 AM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Hey all, I have the Fabtech 6" with 315/70/17's and i seem to rum pretty good, could someone post up some pics and explain a bit on what some of you did to fix it. Thanks.
    Justin
  2. Jan 11, 2010 at 9:19 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Where are you rubbing? Fenders? Body mounts? Front and/or rear?
  3. Jan 11, 2010 at 9:20 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    from what ive read and seen, the tires rub on the body mount. some people cut a small portion of it back and re-weld to close it back up.
  4. Jan 11, 2010 at 9:23 AM
    Chachie
    Justin
    Nor Cal
    Ya i am rubbing the body mount in the front. I havent flexed enough in the rear for it to rub...yet...:D
  5. Jan 11, 2010 at 4:23 PM
    Chachie
    Justin
    Nor Cal
  6. Jan 12, 2010 at 9:17 AM
    mjp2
    NJ
    Cut/grind the body mount and weld some 1/4" plate in there to reinforce it. It's a common mod. Expect it to take you or a fabricator a full day to get it right. It's pretty time consuming.
    Mine are completely smooth from the outer end back to the frame:
  7. Jan 12, 2010 at 9:19 AM
    Chachie
    Justin
    Nor Cal
    and obviously this is a pretty critical part so it would be better to let the pros do the welding huh?
  8. Jan 12, 2010 at 9:24 AM
    mjp2
    NJ
    There are a couple of guys that cut their mounts without reinforcing and haven't had any issues, and they bash pretty hard.
    Personally, I wouldn't take the chance. :)
  9. Jan 12, 2010 at 9:26 AM
    Chachie
    Justin
    Nor Cal
    Oh no, im going to reinforce, but if there are guys that run on no reinforcement then i should be ok doing the welding. That was the only thing i was worried about is the quality of the welds. I mean i have good welds but they are nothing i could get paid for. And yours are just flush with the fender well right?
  10. Jan 12, 2010 at 9:35 AM
    mjp2
    NJ
    My fenderwells are gone. I also took a BFH and smashed the pinch weld flat to eliminate the chance of the metal cutting into the tire when I break stuff, which I tend to do unfortunately often. :eek:
