Behind Rear Seat MOLLE Panels
Discussion in 'Automotive Group Buys' started by N minus 1, Dec 6, 2021.
  1. Dec 6, 2021 at 6:08 AM
    N minus 1
    N minus 1 [OP] Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    UPDATE:
    Underland off road has acquired the MOLLE panel designs.
    please visit www.underlandoffroad.com for current inventory
    Hello!
    Looking to make use of all the wasted space behind the rear seats?
    Ditch the plastic storage bins and bolt in a MOLLE panel!
    ** Access cab panel now includes cut outs for the child seat restraint latches. It fits every 2005+ access cab. Some model years between 2005-2015 require trimming of the rear plastic cab vent or hit it with a heat gun and slightly flatten it (~ 0.5")
    Note: For 3rd gen Tacomas with the power rear window please specify when ordering. Does NOT fit with factory subwoofer.
    MATERIAL: Aluminum
    FINISH: Raw aluminum or powder coat (black)
    Some scratches and scuffs may be present on the raw aluminum finish from the manufacturing process.
    WEIGHT: 12 lbs
    All mounting hardware included for double cab. Access cab reuses 4 factory upper mounting bolts.
    PRICE:
    1st Gen extra cab: $199 + shipping
    2016+ with power window : $325 + shipping (with black powder coat)
    2005+ sliding manual rear window: $325 + shipping
    (With Black powder coat)
    2005+ bedside panel (with black powder coat): 2 for $150 + shipping
    Shipping to the lower 48 is usually between $30-35
    Paypal: rsmryan3@gmail.com
    Local pickup to Santa Ana CA price is discounted $15
    PM me for deliveries to Hawaii, Alaska or outside the US.
    Powder coated 2nd gen DC
    Powder coated 3rd gen (power window)
    Powder coated Access Cab
    Bedside panel in 2nd gen short bed
    Painted and Installed in a 3rd gen
    (no power window)
    Raw aluminum
    (With power window cut out)
    Painted and Installed in a 2nd gen
    Access cab (top)
    DC with power window (bottom)
    DC 2nd/3rd gen (left)
    Custom made shipping boxes to ensure the panels arrive damage free
    1st gen extra cab
    1st gen double cab (fits with rear seat Installed. Seat removed for a clearer picture
    FAQ
    What if I have a factory subwoofer?
    I haven't had a truck with a factory subwoofer to measure yet so you will have to cut a hole to accommodate your subwoofer. An angle grinder with a cutting wheel easily cuts the aluminum.
    How do I paint my panel?
    1: Sand it with 220-320 grit sandpaper. Power sander/orbital sander recommended.
    2: Thoroughly clean the panel
    (Acetone works well)
    3: Spray 2 light coats of aluminum
    primer. Let dry
    4: Lightly wet sand any imperfections
    with a fine scotch brite pad or very
    fine sand paper (500+grit)
    5: Spray 2-3 light top coat layers of your
    favorite color.
    What paint is recommended?
    I use Rust-oleum professional aluminum primer and a Rust-oleum professional high performance enamel top coat.
    The enamel paint takes a long time to fully dry but seems to be more durable in the long term.
    Primer: https://www.rustoleum.com/en/product-catalog/consumer-brands/professional/aluminum-primer-spray
    Top Coat:
    https://www.rustoleum.com/product-catalog/consumer-brands/professional/high-performance-enamel-spray
  2. Dec 6, 2021 at 8:35 AM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Subbed for AC model. :playball:
  3. Dec 6, 2021 at 10:39 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Looks good! Does this secure to the floor at all? Also, is there any way to change the molle pattern -- I am building my power system for behind the back seat [circuit breakers, fuse block, etc] and would happily sacrifice some molle space for a blank spot to cut/mount stuff myself.
  4. Dec 6, 2021 at 1:10 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  5. Dec 8, 2021 at 5:16 AM
    Reddirtnaps
    Reddirtnaps Well-Known Member
    Oklahoma
    2019 DCSB 99 UZJ100
    What’s the lead time on it?
  6. Dec 8, 2021 at 6:33 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    These don't mount to the floor however I know there are a few bolts somewhere on the floor back there, let me look into it and see if I can bend up some brackets.
    The panel doesn't flex very much even when fully loaded.
    All of the panels I currently have are cut for maximizing the MOLLE pattern.
    Sections can be easily cut out with an angle grinder.
    It is possible to make panels that are partially "blank" but it would require a minimum order of 10 panels or a large price increase ($420 ish per panel if I had to guess) The metal supplier I use will make 1 off panels though.
  7. Dec 8, 2021 at 6:36 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    No lead time for these. I have 15 units in stock and ready to ship!
  8. Dec 8, 2021 at 10:37 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    You can always get a flat piece of aluminum, paint to match and drill and tap a few holes in the molle panel to attach the flat piece of aluminum to it. Then you can change the set-up on the flat piece that you attach as your needs change and always have it ready for your particular set up. Win win. Usable molle panel and customizable removable panel. If you need space behind the flat panel you are attaching then just cut it out. The flat piece will cover up what you cut out.
  9. Dec 9, 2021 at 1:52 PM
    Jwlinthicum
    Jwlinthicum VF-1S
    Inland Empire
    2012 DCSB OR
    RCI full skids, Leitner ACS rack, Icon Stage 3, Mobtown sliders, iKamper Skycamp
    Just installed. Rear seats removed, so tons of open space now. Fits perfectly. Thanks Ryan.47428782-D6DD-4DD7-A896-AB8F0ADB21C1.jpg
  10. Dec 14, 2021 at 11:17 AM
    Clymber
    Clymber Well-Known Member
    Vermont
    Trd
    What do you do for sound deadening
    Just load up Dynamat or something like that
  11. Dec 14, 2021 at 11:27 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    I previously had knock off dynamat in there but I had to remove it for an air compressor install and i haven't put anything back in since. A little road noise but totally tolerable.
  12. Dec 14, 2021 at 11:50 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I put Noico behind it, then some decoupler and high density foam. I don’t have noise figures for before and after unfortunately, but I feel like it should be good.
  13. Dec 14, 2021 at 11:57 AM
    BudFriendguy
    Zak
    More than securing to the floor it'd be cool to have a lip that covers that top edge of the sill, even if it doesn't/can't butt right up against the window for whatever reason.
    If not, no biggie, I'll just cannibalize the trim piece I've got over the top.
    What is "decoupler" in this context?
    I usually try and follow deadening discussion because it's high on my "soon..." list.
  14. Dec 14, 2021 at 12:21 PM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    I was looking into the floor mounts and there are a few spots it could be attached but would really need to be made for each particular truck. Unless your mounting some seriously heavy stuff it won't be an issue.
    I actually had a prototype that went up to the window edge and had a small lip bent back to make it look like a clean edge.
    It was really tricky to get perfect and rattled quite a bit. Also came at an extra cost of $45 due to the yield from the large aluminum sheet these are cut from.
    A nice piece of rubber trim would be sweet though. Maybe lowes or home depot would have something
    BudFriendguy[QUOTED] likes this.
  15. Dec 14, 2021 at 3:42 PM
    CttAznRanger
    Brandon
    Boston, MA
    Decoupler would be foam, to let the high density foam, or mass loaded vinyl, to sit off the Noico. Let’s it absorb more of the vibrations in the air.
  16. Dec 14, 2021 at 4:28 PM
    Jwlinthicum
    Jwlinthicum VF-1S
    Inland Empire
    2012 DCSB OR
    Noico. Fairly easy to work with and reduced noise quite a bit.
    Slashaar likes this.
  17. Dec 21, 2021 at 10:40 PM
    iNfectious
    iNfectious Well-Known Member
    Q
    Lone Star State
    '18 TRD Sport 4X4 DCSB
    Might get one soon. Still in stock?
  18. Dec 22, 2021 at 7:06 AM
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Yep I have 8 left in stock!
  19. Dec 22, 2021 at 1:35 PM
    iNfectious
    Q
    Lone Star State
    Nice, I let you know after the holidays for a power window one.
    N minus 1[OP] likes this.
  20. Dec 22, 2021 at 5:39 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    Installed my new panel over the weekend. Sound proofed beforehand with 80mm foil and 157mm foam. Great improvement with noise reduction. Will do the rest of the truck when I do other upgrades. Here are some pics of the install.
