Ruger MkIII disassembly?
Discussion in 'Guns & Hunting' started by jspadaro, Feb 20, 2010.
  1. Feb 20, 2010 at 10:06 PM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Anyone have one of these? The f'ing receiver will NOT come off of the grip!!!! :mad::mad::mad::mad::mad::mad::mad::mad::mad:
  2. Feb 21, 2010 at 5:16 AM
    Pitt1552
    Pitt1552 Well-Known Member
    PA
    2010 Regular Cab 4x4
    After you have the gun field stripped hold the grip in one hand hand tap the rear of the upper with a soft mallet. They are tight for a good while, ive got over 15000 rounds though mine and have taken it down many times and still need to tap it to get it apart. Also, be sure that the mag is out of the gun when doing so... if the mag is still in, she wont come apart.
    http://www.sears.com/shc/s/p_10153_12605_00938388000P?vName=Tools&cName=Hand+Tools&sName=View+All
    I use that with one of the softer tips.
  3. Feb 21, 2010 at 8:22 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Yeah, I did! I whacked the hell out of it with a rubber mallet, and now all I've got is a pistol that won't go together either - it's stuck half-stripped. UGH (Slightly frustrated, lol)
    When I put the bolt in, the bolt release will not come up all the way now, so I think i successfully moved it a little bit forward, but not far enough.
  4. Feb 21, 2010 at 8:24 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Finally got it off! Had to beat the hell out of this thing, jeeez! Thanks for the help
  5. Feb 21, 2010 at 8:26 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Love those Rugers!
    I've been looking for a mkIII hunter 22/45.
  6. Feb 21, 2010 at 9:11 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Gah, I HATE THIS GUN. It's wonderful to shoot, but disassembly is abysmal!!! Everyone who says "Just read the directions" can fuck themselves. :D
    Now when I put the receiver back on the grip, and then slide in the bolt, the bolt release still won't go up completely. I'm assuming this means something is wrong - does anyone know? My mallet and I made sure that the upper is all the way back on the lower.
  7. Feb 21, 2010 at 9:16 AM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    I heard the Rugers were not fun to take apart. That is one reason I bought my wife a Beretta NEOS. It is pretty easy to disassemble, plus it looks pretty cool.
    Tim Glover
  8. Feb 21, 2010 at 10:24 AM
    2 tacomas
    2 tacomas Slightly Sane
    Northern VA
    2006 TRD Sport 4wd -Sold
    I've lost count....
    I love my Mark III, disassembly / reassembly takes under 1 minute once you do it a few times. This link shows you everything you need to know and helped me a lot the first few times.
    http://www.guntalk-online.com/fsprocedures.htm
  9. Feb 21, 2010 at 11:44 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Yeah, well, thanks for the link, but I think this one might have to go back to ruger.
    When I put the bolt in, the bolt release doesn't slide up. Something is wrong here :(
  10. Feb 21, 2010 at 11:53 AM
    2 tacomas
    Northern VA
    I've lost count....
    It sounds like you don't have the hammer fully forwards or the hammer strut is not in the proper position. Look at steps #6 and #8 again in the Ruger Mark III Field Stripping Reassembly Procedures link that I posted. I had the EXACT same issue when I first tried to clean my gun....it's frustrating the first time you do it yourself but once you figure out the right positions it will take you no time at all. If need be, post some pics of how you have everything right now and I can try to help you out.
  11. Feb 21, 2010 at 11:57 AM
    Carlo
    Carlo Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    I had the same negative experience with my MkIII, the instructions suck. I had to do it a few times before I got it. Now, I just shoot it and dont worry too much about cleaning it like when it was new. I use a qtip and swab out the chamber area and a little lube. Mine shoots great. My only other complaint was the rear sight came loose after a few hundred rounds. I had to lock tight and lightly stake it. Weird.
  12. Feb 21, 2010 at 12:04 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Hm... The hammer is down when I slide the bolt in, but the bolt release (I'm referring to the button above and slightly to the rear of the trigger) will not move fully upward when I first put the bolt in, or ever. (Really wanting to curse here, I'm about to toss this thing in the trash.) But I do appreciate the help. :)
  13. Feb 21, 2010 at 12:14 PM
    2 tacomas
    Northern VA
    I've lost count....
    Check out some of the other links off of the main link I posted earlier, some of them are much more detailed and should help you out. I can pretty much guarantee that nothing is wrong with your gun...it can just be like a rubix cube the first time you try to take it apart and put it back together.
    Troubleshooting / solutions:
    http://www.guntalk-online.com/TroubleshootingPage.htm
    Bolt Assembly:
    http://www.guntalk-online.com/detailstrip.htm#bolt
    Good close-up of parts:
    http://www.guntalk-online.com/mk3_pistol_nomen.html
  14. Feb 21, 2010 at 12:19 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Grrrr.... Now I can't get the fucking bolt stop pin to go through the bolt either. When I put it in with the bolt out, it's fine. When I put it in with the bolt in, it doesn't go through completely. This thing sucks.
  15. Feb 21, 2010 at 12:38 PM
    2 tacomas
    Northern VA
    I've lost count....
    If I were you, I would take a break from the gun for a few minutes. Go drink a beer, watch some of the race, and then go back to working w/ the gun. I recommend completely stripping everything and starting over.
    Sometimes you just gotta walk away for a few :)
  16. Feb 21, 2010 at 2:19 PM
    Pitt1552
    PA
    when you go to put the bolt stop pin in make sure that the little black bar in the grip isnt caught on the cross bar going through the grip... it should be swinging freely. the gun is a pain in the rear at first, but ya get to learn the quarks about it with time... i still manage to forget a step or two here and there... and kick myself when i realize what i forgot... great gun though. i have a mkIII hunter and the only problem ive had with it are the sights not being real good for target shooting... but from what ive heard ruger will send ya a new rear blade free of charge. Ended up throwin a red dot on there yesterday... gotta get her out to the range for some fun.
  17. Feb 21, 2010 at 2:21 PM
    emtlibby
    emtlibby Slaughtering goats
    Boston, MA
    2010 4x4 DBLCAB
    Mine requires the snot to be beat out of it to come apart. It gets easier the more times you do it. Also, try putting it in the freezer first! Worked for me.
  18. Feb 21, 2010 at 2:25 PM
    JeffRock
    Capital region, NY
    True words of wisdom there!
  19. Feb 21, 2010 at 2:28 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Agree, I would start over after a break.
  20. Feb 21, 2010 at 2:34 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I have a mkIII 22/45. I put about 300 rds in it yesterday and it locked up on me. I oiled the hell out of it and it is working great again. I havent tried to field strip it for the reasons mentioned above. Has anyone else had jamming issues. I think it may be because the bolt wasnt oiled enough but my ammo gets jammed a lot when it is trying to get jacked into the chamber. Almost all ammo has done this.
