Rumbling sound around 30 mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BenSkiv, Aug 2, 2024.
  1. Aug 2, 2024 at 3:32 AM
    BenSkiv
    BenSkiv [OP] Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    Hey all! I’ve got a 19 TRD OR, it has a 3” lift, I did the ECGS bearing replacement lately. I’ve only owned it for a month so not certain if it’s normal, but around 30 mph it makes almost a rumbling sound and has a bit of vibration. It doesn’t matter if I’m on the gas, braking, or coasting, it’ll do it. It’s actually worse when I’m on the brakes compared to when I’m speeding up. Leaning towards wheel bearing possibly? Any ideas or suggestions on what to look at? Thanks!
  2. Aug 2, 2024 at 4:15 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Drive straight down the road at this speed of noise, turn the wheel slightly to the right & left if noise increases or decreases this is a wheel bearing. Option # 2, jack up all four wheels. Remove a anti-lock brake sensor wire on one wheel or abs fuse /relay what ever so the abs & traction control will not activate, start it up IN 4WD, put it in gear with a friend raise the speed up to 30 to 40 put your hand on a coil spring at this speed and see if you can feel a rumble feeling in the spring if you can replace that bearing..note: this worsens when you apply the brakes because you are putting more weight on the front of truck..also with wheels off the ground grab the wheel at the 12 & 6 o'clock position see if there is any movement, should have zero lash..
  3. Aug 2, 2024 at 4:23 AM
    BenSkiv
    Ben
    Maine
    It seems to lessen when turning right, it doesn’t completely disappear but it lessens. I’ll confirm for sure on the way home today. I can definitely do it myself, I’ll just do the whole hub since it’s easier.
  4. Aug 2, 2024 at 4:24 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    your welcome
    BenSkiv[QUOTED][OP] likes this.
  5. Aug 2, 2024 at 11:01 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Could be a warped brake rotor possibly also if only feel it up front
  6. Aug 2, 2024 at 4:27 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I would think simply press & holding down the VSC button overhead would do the same thing.
    But yeah, sounds like wheel bearing to me also.
  7. Aug 5, 2024 at 4:57 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    YES correct I did not think about that...
  8. Aug 5, 2024 at 5:07 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    From what I’ve read on here front bearings are common failures. The fact that it changes when you turn is a good indicator.
  9. Oct 1, 2024 at 3:53 AM
    BenSkiv
    Ben
    Maine
    Never ended up figuring this out. Sound happens around 30 and 60, it does not change pitch at all. It’s just a consistent sorta rumble sound. Thinking it might be scalloped tires.
