run a SUBPUMP off the bed outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rudy0077, Oct 27, 2012.
  1. Oct 27, 2012 at 2:36 PM
    rudy0077
    rudy0077 [OP] Active Member
    Rudy
    South Jersey
    TRD 6 cyl. Lucille the Dark Horse
    04/27/2012 - Picked up at Toyota Dealer 5/4/12 BFD Wheels URD TCAI AFE Exhaust BHLM Toytec 3 Inch Lift Memphis 12'' shallow sub in tacotunes box Rigid D2 Dually Fogs behind the grill
    Anyone ever run a 3.5 amp sump pump off of the bed outlet in the back of a 2012 tacoma? Just looking to see worst case scenario of this generator craps out.
  2. Oct 27, 2012 at 2:41 PM
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Whats a sub pump?
    you mean sump pump?
  3. Oct 27, 2012 at 2:44 PM
    rudy0077
    Rudy
    South Jersey
    yup sump pump
  4. Oct 27, 2012 at 2:45 PM
    bullaculla
    Honolulu HI
    Sorry, wasn't trying to be a dick. I never heard anyone call it that, but it is submersible so I can understand.
    3.5 amps at 120V =420 watts. Its only rated for 400 in idle. I wouldn't do it.
  5. Oct 27, 2012 at 2:46 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    i know it will run a hair dryer on low while the truck is running if that helps.
  6. Oct 27, 2012 at 2:53 PM
    rudy0077
    Rudy
    South Jersey
    in that case anyone know whats the worst that can happen? if the invertor goes then i could deal with that but not doing any lasting damage to the truck bc then ill go nuts.
    i just tested it to see if it would work and the pump worked but dont know much about electricity and dont know what would happen for a prolonged period of time.
    by the way the world is ending in new jersey so thats why im trying this nonsense
  7. Oct 27, 2012 at 2:55 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Everything is fused. Toyota knows someone will try to run a Skilsaw or something off that outlet, they planned accordingly. I'd go for it.
  8. Oct 27, 2012 at 2:56 PM
    dbkid05tacoma
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    all that happens is the outlet turns off and you have to go push the button again it has a built in cut off switch. by the way good luck just heard about whats happening.
  9. Oct 27, 2012 at 3:21 PM
    Failure2Comply
    Failure2Comply Well-Known Member
    Virginia, USA
    05 Access TRD/SR5 4x4
    NFab bars, bed mat, Weathertech mats.
    And that does not take into consideration the "start-up amps" the pump motor will draw.
  10. Oct 27, 2012 at 3:24 PM
    bullaculla
    Honolulu HI
    Yep, according to the manual, it has a protection circuit and will just cut power and have to be reset. also a 3.5A pump doesn't mean it will pull 3.5 amps all the time.
  11. Oct 27, 2012 at 3:27 PM
    rudy0077
    Rudy
    South Jersey
    i think ill give it a try when the power goes down. thanks fellas...good thing is im all the way by philly but according to the latest tracking we're supposed to have zombies out and about with this being the end of man kind. take care
  12. Oct 27, 2012 at 3:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Nice knowing you.:D
  13. Oct 27, 2012 at 5:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Dude-If you are worried about the storm you need a generator, not to try to run a piece of vital equipment off a barely or not quite capable power source.
    Don't try to be cheap and end up becoming a victim.
  14. Oct 27, 2012 at 10:00 PM
    bullaculla
    Honolulu HI
    he's got a generator, just wants to make sure the truck outlet is an adequate backup ;)
  15. Oct 28, 2012 at 3:22 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    11 trd sport longbed
    weathertech visors,remote start,lojack, ARE z type topper, wet okole seat covers, pop n lock tailgate lock
    you can always go to a home store and buy a battery backup pump system...basement watchdogs a good one and simers ace in the hole is not !! i run both a pedestal and the battery backup at my house just in case. generator also in case of a longer than 7 hour loss of power.fill those gas cans now.....good luck in this storm peeps...be safe
  16. Oct 28, 2012 at 5:11 AM
    rudy0077
    Rudy
    South Jersey
    thanks bullacula.
  17. Oct 28, 2012 at 5:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Fair enuf-I missed that. Still not something I would try. If the generator is questionable...I'd be working on making sure it'll run or setting up a battery back up.
  18. Oct 31, 2012 at 9:17 AM
    rudy0077
    Rudy
    South Jersey
    didnt have to use generator or truck....whew, dodged a bullet. power never went out even though half the state is in ruins
  19. Oct 31, 2012 at 9:19 AM
    acdronin
    acdronin Well-Known Member
    Quick answer is no, it won't run it, that circuit is only rated at like a half-amp
  20. Oct 31, 2012 at 9:35 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Actually 400w = about 3amps
    And he tried it, the pump did work off the bed outlet
