Run in 4wd once a month?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JAMC, Jul 3, 2019.
  1. Jul 4, 2019 at 6:26 AM
    #61
    Failure2send
    Failure2send Well-Known Member
    2018 TRD Off Road
    You're fine to run it in 4H as long as you're driving in a straight line and are under 52 (say 50 for margin of error) MPH. Just pick a section of a road near you that's straight for a mile or two and click it into 4H.
  2. Jul 4, 2019 at 6:31 AM
    #62
    jdr3366
    jdr3366 Well-Known Member
    I never go over 50 mph. Always maintain a margin of error.
  3. Jul 4, 2019 at 6:32 AM
    #63
    Failure2send
    2018 TRD Off Road
    Good call!
  4. Jul 4, 2019 at 6:50 AM
    #64
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Pardon my ignorance, but what is the significance of 52 mph?
    Thanks in advance.
    Skip
  5. Jul 4, 2019 at 6:54 AM
    #65
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can go as fast as you want in 4wd. You just have to be under 62mph to engage it (at least in 2nd gens)
    Lawfarin and beergeek like this.
  6. Jul 4, 2019 at 6:56 AM
    #66
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Wasn’t that a Gun’n’Roses album?
    hiPSI[QUOTED] likes this.
  7. Jul 4, 2019 at 7:02 AM
    #67
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Nope, that was an Axl Rose album.
    hiPSI and Stocklocker[QUOTED] like this.
  8. Jul 4, 2019 at 7:11 AM
    #68
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Wow, the 4wd systems on these trucks aren’t as sensitive as the feelings of some of the members in here....
    BSFord likes this.
  9. Jul 4, 2019 at 7:15 AM
    #69
    Stocklocker
    17TRDORDCSBAT
    Truth!
  10. Jul 4, 2019 at 7:21 AM
    #70
    skiploder
    FZJ80/XJ LS swap
    I know that because, well, I read my manual.
    Still wondering why two people in this thread are recommending 52 mph.
  11. Jul 4, 2019 at 7:22 AM
    #71
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My guess is they’re just confused and misread/misunderstood the manual.
    hiPSI likes this.
  12. Jul 4, 2019 at 8:00 AM
    #72
    skiploder
    FZJ80/XJ LS swap
    This isn’t directed at you..it’s directed at every piss-flap that mewls and whines when one of us recommends reading the fucking manual before posting a question. This doesn’t apply to the OP...as the OP actually read the manual and was pointing out a legitimate source of confusion contained therein.
    Again, the OP asked a question and to his credit, read the manual. The discussion has since veered into a combination of accurate and inaccurate advice. While the manual doesn’t tell you how to put your 10 miles a month of 4hi in, it does give you clear guidelines with regards to engaging/disengaging it.
    In two places, the manual mentions 62 mph as the upper limit to ENGAGE 4hi. It even tells the reader that it will not shift into 4hi over 62 mph. It will buzz and blink.
    While the manual does caution against running 4hi on hard and dry surface roads (the source of confusion to many who actually read the manual) no harm will occur if you put it in 4hi, once per month on a hard, dry surface road without making any turns, and going at a moderate pace.
    treyfive and whatstcp like this.
  13. Jul 4, 2019 at 8:06 AM
    #73
    SpeySquatch
    2016 TRD OR DCSB
    I ran mine on pavement in a straight line at 55 and it started to get a weird vibe...I don’t do that anymore
  14. Jul 4, 2019 at 8:44 AM
    #74
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Let me answer, hopefully and people will understand. Moab rock is "The sandpaper texture is notorious for inflicting severe abrasion injuries. The name "slickrock" was given by early settlers of the area because their horses' metal shoes had difficulty gaining traction on the rock's sloping surfaces."
    This is not me below. I just googled MOAB 3rd gen Tacoma. You don't do this in 2HI. The guys who say your truck will explode don't have much experience off road.
    This is a bit worse than the road to your local grocery store.
    OP, you will be fine. Just don't do a lot of parking lot turns for several hours in a row.
  15. Jul 4, 2019 at 8:50 AM
    #75
    GrievousAngel
    GrievousAngel Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    Read to the end. Didn't see this addressed. I'm curious as well.
  16. Jul 4, 2019 at 8:53 AM
    #76
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    Good question, and hears why (assuming the 4x4 systems are the same on T4R and Tacoma)
    The 4th gen 4Runner uses an electronic motor to “activate” 4 wheel drive, called an “actuator”. It has another actuator to engage 4lo, and if it is not used often enough the actuator freezes- an expensive repair because the transfer case needs to be opened to remove the actuator. Although it bolts onto the transfer case, it has internal parts. If you try to remove it by just unbolting it, the transfer case will be damaged. More $. One of the weak points of the 4Runner, and possibly the Tacoma if the same systems are used.
    My 1st gen taco has all manual system, no issues since 1998, and I don’t drive 10 miles a month in 4x4
    If your system has a manual lever to engage 4x4, then all this actuator business may be irrelevant.
    If your Tacoma has a center differential then you would be able to drive it in 4x4 on dry pavement, turns, straight lines, whatever.
    2016Tacoman[QUOTED] likes this.
  17. Jul 4, 2019 at 8:58 AM
    #77
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Your point? Wheeling puts stress on the truck in general. Wheeling Moab just puts more stress on the truck.
  18. Jul 4, 2019 at 8:58 AM
    #78
    GrievousAngel
    I'd say the stark (and entirely reasonable) differences of opinion in this thread is why this keeps coming up. There is no consensus.
  19. Jul 4, 2019 at 9:08 AM
    #79
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    The difference is the road to the grocery store doesn't ever have different traction under each tire. In this picture there is no possibility of binding, because one of the wheels is in the air.
    My old boss grenaded the transfer case on an f-450 driving it down the highway in 4wd. Do people do it without damage? Sure. But it seems like an unnecessary risk.
  20. Jul 4, 2019 at 9:13 AM
    #80
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not directed at you at all. Just most people don't understand that a simple off road trip is much worse on the components than driving on pavement in 4HI. Sorry!
    Stocklocker likes this.
